Author Topic: oil drain plug  (Read 6140 times)
hrlyfxdl
oil drain plug
« on: November 23, 2016, 03:31:06 PM »
I am looking for any information or pictures on what the original oil drain plug would look like for a 1968 Camaro. The car has a 350 in it, it's supposedly an SS (not sure if that matters on this issue). I see so many different kinds out there for sale from vendors and 2nd party, not sure what it a correct finish or marking. Went through the other forum discussion and didn't see any images. Thanks for any help.
1968 Camaro SS 350 8L34677?
07A  E107  TR 712  U-U
5hane
Re: oil drain plug
« Reply #1 on: November 23, 2016, 03:51:29 PM »
Quote
That's because there isn't just ONE correct plug. There were multiple suppliers so multiple markings.
hrlyfxdl
Re: oil drain plug
« Reply #2 on: November 23, 2016, 03:53:16 PM »
Good to know Ed, thank you for the info.
07A  E107  TR 712  U-U
5hane
Re: oil drain plug
« Reply #3 on: November 23, 2016, 04:10:30 PM »
Here are just 3 of the many I've seen. Different (or even NO) markings, but they all have one thing in common. They all have the "shoulder".
Re: oil drain plug
« Reply #4 on: November 23, 2016, 05:29:44 PM »
Looks like SB are different styles than BB?
Re: oil drain plug
« Reply #5 on: November 23, 2016, 05:52:48 PM »
Quote
Nope. All engines used the same size drain plug (1/2"-20 thread), but there WERE two different sizes for the hex head used. Up until sometime in 1968 (exact date unknown), the head used a 7/8" wrench, and then after that they used a 9/16" wrench. All were interchangeable other than that.
However, in answer to the OP's original question, even though the books say the changeover date was sometime in 1968, I've never seen a 68 Camaro with the early 7/8" head plug. Another interesting research topic?
« Last Edit: November 23, 2016, 06:23:04 PM by bertfam »
Re: oil drain plug
« Reply #6 on: November 23, 2016, 06:26:56 PM »
Hi Ed,
  The size is what I meant in relation to the type (or style). I checked both 67 L35's (March and April assembly dates) and they have the 7/8" plug though with different head markings.
Re: oil drain plug
« Reply #7 on: November 23, 2016, 10:57:32 PM »
Our 68 has a RSC drain plug.
Re: oil drain plug
« Reply #8 on: November 24, 2016, 12:18:29 AM »
Here ya go Mike.  03D 68
Re: oil drain plug
« Reply #9 on: November 24, 2016, 01:06:14 AM »
  Hi Darrell,
       Mine looks like the 55-68 style picture posted. Though the usage period is said to be 55-68 it looks like the ones posted for '68, including yours, is the smaller head style.
Thanks!
Re: oil drain plug
« Reply #10 on: November 24, 2016, 03:33:31 AM »
Here's a drain plug on a '67 302 Z-28 engine. It uses the 7/8" wrench.
