Author Topic: Muncie metal trim tag identification  (Read 23177 times)
Re: Muncie metal trim tag identification
« Reply #15 on: December 08, 2016, 05:41:00 PM »
Dave, it all depends on which AIM you're looking at. 1967, 1968 and 1969 all used different part numbers. The picture James posted above is from the 1969 AIM.
Dave O.
« Reply #16 on: December 08, 2016, 07:58:34 PM »
Ok, thanks. Mine is for a 68!
« Reply #17 on: December 08, 2016, 08:21:40 PM »
Quote
In that case you have this (see below).
dutch
« Reply #18 on: December 09, 2016, 04:24:15 AM »
Do any of the retailers make or sell reproduction Muncie Tags as shown..
Looked some and don't see any, but mine is MIA as I suspect most are and I wouldn't mind getting a 3915085 version if they are being made or reproduced.
I just assumed since they remake radiator tags, rear end posi tags, and all kinds of repro decals and such - that little metal tags would also be available - or maybe the demand just isn't there?!
Thanks - Randy
« Reply #19 on: December 09, 2016, 04:48:16 AM »
Quote
Not that I know of. Your best bet is ebay. YOU JUST MISSED ONE!
« Reply #20 on: December 09, 2016, 01:19:54 PM »
I've seen some for sale on eBay that are reproductions but the fonts are not 100%. That is only obvious if you compare it side by side to an original. I think for a show you'll be fine.
« Reply #21 on: December 09, 2016, 03:15:34 PM »
To answer the above question(s), yes, there are repros; good ones, too. The following link will get you to the retailer - their '68 tag is the wrong number, but they have all of the '69 part numbers.
https://www.thepartsplaceinc.com/
You just have to know where to look. I've done some business with these guys, pretty darn good reproductions in a lot of different categories. Just click on Camaro, the year, search for trans tags -
dutch
« Reply #22 on: December 09, 2016, 03:53:50 PM »
Thanks Steve - I had looked there previously prior to posting but obviously didn't use the search option correctly, since when I went back after your reply, I found them easily the second go-around..
Too bad they don't have the proper number - is the one they show even at all legit for a '68 model?
Regardless, I can't see wasting money (and shipping up here = more $$'s and brokerage fees) for something that isn't even at all correct number-wise.. Too Bad!
I'll have to watch E-Bay as others have suggested..
Thanks again for your trouble - Randy
« Reply #23 on: December 10, 2016, 02:42:57 AM »
Randy, I thought Heartbeat was selling the repro's also but did not verify. Years ago they were still pretty easy to spot a repro but maybe they are better now.
From the Yenko website: "Lots of people contributed,but credit goes to Chuck Hanson for publishing this all in last months Chevelle World.Box #28 on the Buildsheet will reflect the 2 letter code as well."
Muncie ID Tags
1964 M20 3841435
1965 M20 3857577
1965 M20 3857578 Z16
1966 M20 3870357 L-34 L-35
1966 M20 3890534 L-78
1966 M21 3877459 ALL
1966 M22 3879993 L-78
1967 M20 3870357 L-34 L-35 L-79
1967 M21 3877459 ALL
1967 M22 3879993 L-78
1968 M20 3915079 L-34 L-36 L-78 L-79
1968 M21 3915085 L-34 L-36 L-78 L-79
1968 M22 3925626 L-78
1969 M20 3950301 L-48 L-35
1969 M20 3946767 L-34 L-78
1969 M21 3946798 ALL
1969 M22 3950318 L-78 COPO L72
1970 M20 3952659 WB
1970 M21 3968012 (disc.3-11-70)
1970 M21 3968011 WL
1970 M22 3978766 WO
1971 M20 3974484 WN
1971 M22 3978766 WO
1972 M20 3974484 WN
1972 M22 6271517 WJ
« Reply #24 on: December 10, 2016, 03:12:31 AM »
Our M21 metal ID tag from our 68 Z Randy prior to restoration.
« Reply #25 on: December 10, 2016, 03:12:37 AM »
Randy, I will check to see if I have an extra. If I do I will send you a PM.
Chick, that list was for Chevelles. Note their are no listings for Z28.  The AIMs for each year are the best source for the data.
dutch
« Reply #26 on: December 10, 2016, 01:13:12 PM »
Bryon, Thanks for your looking..  Its certainly not a life threatening deal, but it would be something that would be nice to add and again I appreciate your effort...
Chick - the list you posted and the picture of yours shows the right one I need I guess from everything I've read now and seen - again you were so very fortunate in having such an original car right from the outset!
Randy
crashent
« Reply #27 on: December 22, 2016, 04:38:03 AM »
Post #23 is a pretty good list of trans assembly part number tags, but there is an error with the 1969 M-20 part numbers is 3946797 not 3946767 as listed...
I've seen the part number tags from the parts place, IMHO you will not be happy...
Hope this helps... Crash
« Reply #28 on: December 22, 2016, 04:14:59 PM »
Thanks Crash. I agree. The repro tags are not even close.
