Author Topic: First Gen dual exhaust hanger plates..  (Read 37200 times)
Re: First Gen dual exhaust hanger plates..
« Reply #60 on: November 13, 2016, 11:08:32 PM »
07B 1967 Z28 from the NOR plant, less than 80 cars from the end of production, does have the driver's side riv-nut inserts.
10A 1968 Z28 from the NOR plant, also has the inserts.
« Last Edit: November 14, 2016, 03:00:34 AM by Jon Mello »
« Reply #61 on: November 13, 2016, 11:25:46 PM »
Update:
1967 LA
Build Date  Rivnut?   Reference by
04B           No         Mike S
06B           No         Troy Criscillis
06D           No         Jon Mello
07B           No         Jon Mello
1967 NOR
Build date  Rivnut?   Referenced by
06E          Yes        Bill Glowacki
07B          Yes        Jon Mello
1968 LA
10C          No          Dana
01C          Probably  Martin Foltz
02C          Yes        Paul
1968 NOR
10A          Yes        Jon Mello
RS Copo
« Reply #62 on: November 14, 2016, 12:02:14 AM »
Ed, you have a PM.
On a previous post I said I had a threaded plate near the shock facing out from the frame rail on the pass side.I wondered if it was for the exhaust,it is for the rubber bumper,sorry!
« Reply #63 on: November 14, 2016, 12:10:22 AM »
That's okay Dana. I'm not concerned about the passenger side of the car. Only the driver side.
« Reply #64 on: November 16, 2016, 01:58:29 AM »
05A 1967 Z28 from the NOR plant, does have the driver's side riv-nut inserts.
« Reply #65 on: November 16, 2016, 04:31:12 AM »
03B 1967 Z28 from the NOR plant does not have the driver's side riv-nut inserts.
« Reply #66 on: November 16, 2016, 02:16:10 PM »
Update:
1967 LA
04B           No         Mike S
06D           No         Jon Mello
07B           No         Jon Mello
1967 NOR
03B          No         Jon Mello
05A          Yes        Jon Mello
06E          Probably  Bill Glowacki
07B          Yes        Jon Mello
1968 LA
10C (67)    No          Dana
02C          Yes         Paul
1968 NOR
10A (67)    Yes        Jon Mello
Thanks fellas. Keep it up!
« Last Edit: November 16, 2016, 02:47:57 PM by bertfam »
« Reply #67 on: November 16, 2016, 02:51:02 PM »
 Ed,
   This is still for coupes only and it is assumed the convertible didn't use them for 67-69 due to the thicker rails, correct?
« Reply #68 on: November 16, 2016, 02:54:41 PM »
Quote
This is still for coupes only, correct and it is assumed the convertible didn't use them for 67-69due to the thicker rails, correct?
That's correct Mike. Only for 1967 and 1968 Coupes.
« Reply #69 on: November 16, 2016, 08:42:09 PM »
Ed, our 68 NOR 01B has riv-nuts on left (drivers) side.
« Reply #70 on: November 16, 2016, 09:25:08 PM »
Update:
1967 LA
04B           No         Mike S
06D           No         Jon Mello
07B           No         Jon Mello
1967 NOR
03B          No         Jon Mello
05A          Yes        Jon Mello
07B          Yes        Jon Mello
1968 LA
10C (67)    No          Dana
02C          Yes         Paul
1968 NOR
01B           Yes        Chick
67jeffreyt
« Reply #71 on: July 25, 2021, 03:11:11 PM »
I know this an old post but I just replaced my exhaust and my 67 01C date, and has small holes on driver's side and passenger side.  There's no way riv nuts would have fit.
« Last Edit: July 25, 2021, 03:45:07 PM by 67jeffreyt »
67 ss/rs camaro currently
68 prostreet Camaro 9.60 1/4 mile
68 Rallysport, first car high school
89 rs camaro convertible, made readers rides super Chevy
plumL78
« Reply #72 on: July 26, 2021, 12:26:00 PM »
I did a 67 Z from LA that didnt have rivnuts
