I can't quite get how to do multiple quotes,but BC Miller, the holes on the dr side frame rail behind the tire are not threaded.
Ed,it is an Oct 67 car. I see the taping plate on the dr side ,next to the shock,on bottom side of the frame rail.I also see the holes in the same location on the pass side,but no taping plate installed.However, next to the shock on the pass side frame rail,facing out towards the tire, there are two holes with a taping plate.
On the floors, forward of the rear end housing,there is a taping plate for a hanger on the dr side only. Just two holes on the pass side.Thank you.
Dana
