Author Topic: Speedo Gear Reducer  (Read 19686 times)
Re: Speedo Gear Reducer
« Reply #15 on: November 04, 2016, 11:23:23 PM »
And other manual transmissions as well.
L78 steve
« Reply #16 on: November 14, 2016, 02:39:16 PM »
You can do a drive gear swap without pulling the trans. Just be careful not to let the counter shaft pin to pull out with the tail-shaft housing allowing the thrust washer to drop. If it does it can still be re-positioned just a PITA.
69 Z/28 Dover White. SOLD
