Author Topic: MCACN  (Read 23026 times)
Re: MCACN
« Reply #15 on: November 03, 2016, 02:26:58 AM »
Chick, just an FYI. I took my rear leaf springs to a spring shop and had them re-arched two separate times until I got the ride height where I wanted it. It's an option for you to consider if the car doesn't end up settling where you want it to.
Re: MCACN
« Reply #16 on: November 03, 2016, 04:58:16 AM »
Not to hijack, but when you did that do they heat up the springs? or how do they re-arch them, and do it a little at a time, and evenly to both?
Re: MCACN
« Reply #17 on: November 03, 2016, 01:49:38 PM »
They did not heat them. It's just put in a fixture and I believe they use a press to change the arc of the spring one way or the other.
Re: MCACN
« Reply #18 on: November 03, 2016, 01:56:15 PM »
thanks
68L30
Re: MCACN
« Reply #19 on: November 03, 2016, 08:48:37 PM »
I'll be there, looking forwad to seeing the Z !!
ds1
Re: MCACN
« Reply #20 on: November 05, 2016, 12:43:52 AM »
NAPA68
Re: MCACN
« Reply #21 on: November 06, 2016, 06:40:03 PM »
I'll be there with my 68 in the Day 2 display.
Daytona Z
Re: MCACN
« Reply #22 on: November 06, 2016, 08:16:08 PM »
Love that Day-II 68, and cant help but dig Chick's 68
Wish I was going but isn't a reality this year.
Just an obsessive-compulsive first gen car guy...
did I mention I like three pedals in a car?
Re: MCACN
« Reply #23 on: November 06, 2016, 11:19:49 PM »
 Grady and me will be there in the day 2 display with Grady's B Brown 69 COPO Camaro, it's still going together, whew !
Mike, how you making out with Grady's 69 COPO Camaro?
I did add a few detail things to our car prior to the show including the correct Roger Dean script on the tail pan panel Steve gave me, the repro window sticker, and an earlier more correct Y55 battery. Know the yellow script is not correct with what came from the factory but it looks nice and will leave it on for this show. Build thread has info on how the script was applied with 3M adhesive.
m22mike
Re: MCACN
« Reply #24 on: November 07, 2016, 01:22:47 AM »
 Front clip going together now, still have the pinstripes and final polish yet. Hope you can here it run, OMG what a thumper.
Re: MCACN
« Reply #25 on: November 07, 2016, 06:06:06 AM »
Chick,
FWIW, rear bumper guards were included with Z28 - they weren't an option for that model.
Re: MCACN
« Reply #26 on: November 07, 2016, 01:09:12 PM »
Chick,
Yep, know that Kurt but admit I missed it when first proof read prior to arrival but with the mistake and stating/showing the repro window sticker in the build thread there should be no mistake its a reproduction.  I wish I had your eagle eye for things like that and I mean that in a most positive remark. :)
A side note: Using child's water based glue sticks go on easy, dry completely clear, and if you want just grab the paper and it peels off with easy clean up. I experimented with a couple glues on my entrance door glass prior. LOL
Re: MCACN
« Reply #27 on: November 07, 2016, 01:36:39 PM »
I would have done the same. It is a good finishing touch on a nice body of work.
If my car ever makes it to a show (probably MCACN if any), I would consider putting together something like that. I assume since my car was a dealer trade, the original window sticker would have the first selling dealer, and they would not have made a new sticker for the the dealer that the car was eventually sold through?
Re: MCACN
« Reply #28 on: November 07, 2016, 02:16:40 PM »
Austin:  NO new window sticker, regardless of how many times a new car may have been 'traded' between dealers... window sticker would show the 'original' dealer it was shipped to.
ban617
Re: MCACN
« Reply #29 on: November 16, 2016, 05:49:48 AM »
I hope to be there & check out that fine machine you have ...
