Author Topic: 68 remote outside mirror  (Read 40484 times)
Re: 68 remote outside mirror
« Reply #15 on: February 09, 2007, 11:51:55 PM »
Paul, read THIS. Especially the part regarding the P&A Manuals (Number 1, 2 and 3 under the "VERY difficult to find section. These are what you need to find this obscure stuff!!
68rsssrag
« Reply #16 on: March 18, 2007, 11:14:05 PM »
I got repro mirror #2 and it has the same problem....and no drain holes.
Does antone have a contact for OER that i can call. They have no info on the box or website.
Arno
camaromikey
« Reply #17 on: March 19, 2007, 04:33:47 PM »
does anyone have the correct orignnal number for the 69 remote mirror. i brought one but i don't think its right. when i mounted it with its orignnal hardware it sat at an angle.
« Reply #18 on: March 19, 2007, 06:46:21 PM »
Arno, no phone number, just the email from their site:
info@oerparts.com
camaromikey, the original 69 Camaro Remote Mirror part number was 3957203.
camaromikey
« Reply #19 on: March 20, 2007, 03:34:31 AM »
where are the numbers located. the mirror face has 9-dmi-9. the head has 14-2269 inside, and base has 15-2270 inside the base. also the bezal has 3958372 on it.
« Reply #20 on: March 20, 2007, 04:30:28 AM »
camaromikey, the part number (3957203) won't be found on the mirror. However, 9-DMI-9 indicates a date code of September, 1969. 14-2269 and 15-2270 I believe, are the correct casting numbers for a 69 Remote Mirror base and head, and 3958372 is the correct bezel for a 69 Camaro with Standard Interior. HOWEVER, these same numbers may have been used on other models and/or years as well. I know for sure the Bezel was also used on the 70 Chevelle, so you might have a mirror for that car. My books don't go up that far, so maybe someone else can give you more info.
You do know that the mirror can be adjusted, right? Loosen the screw on the back and adjust as necessary. If it's still wrong after that, you probably have the wrong mirror.
« Last Edit: March 20, 2007, 04:46:54 AM by bertfam »
68rsssrag
« Reply #21 on: March 20, 2007, 05:04:35 AM »
I tried that email twice with no response. Suggests they are not getting feedback that could help improve the product.
Too bad since they seem to have some good stuff like their rubber bumpers.
Arno
camaromikey
« Reply #22 on: March 20, 2007, 06:34:35 AM »
this one has no adjustment, the head has to pegs that line up with slots in the base. i think thats what i have is one for an impala or chevelle. its a bummer becuase its in perfect shape. almost no pitting. I was just hoping i was doing something wrong. thanks
« Reply #23 on: March 20, 2007, 02:04:17 PM »
OOPS! Yeah, your're right. I was thinking 68. (That one's adjustable.) Sorry about that.
