Author Topic: rear bump stop bracket finish  (Read 4097 times)
« on: October 24, 2016, 12:03:15 AM »
Maybe tired, can't find the color for the rear bump stop bracket in my references. Semi gloss?
Re: rear bump stop bracket finish
« Reply #1 on: October 24, 2016, 01:34:16 PM »
Can you further clarify exactly which part you are referencing?   Does 'rear' refer to the differential bump stop? or ??
PS.  My car is a '69, and '68's may be different, but the differential stop bracket on my car seems to be attached permanently to the floor reinforcement and was primed/painted when the floor was done.. ie.. so mine has a mix of primers (not much color overspray in that area)...  If this is what you want to see, and my '69 would help, I can post a pix...
« Reply #2 on: October 24, 2016, 03:17:57 PM »
Differential. IMO, semi gloss with gray phosphate fasteners would break it up nice. Floor pans finally painted as of yesterday, along with rear wheel well undercoating.
« Reply #3 on: October 24, 2016, 11:55:38 PM »
Semi gloss black and yes phosphate bolts. I was not sure of which part you were referring to also. :)
« Reply #4 on: October 25, 2016, 11:43:23 AM »
Thanks.  Wrapping up the firewall this weekend, as my hold off valve should be coming back from Brake boosters. I rebuilt the diff valve(very easy). Also want to get the core support and front wheel wells in primer.Will be posting some progress pics in a few days.
