Author Topic: 1969 rear speaker ground tab  (Read 7630 times)
Danzo
« on: October 23, 2016, 12:43:37 AM »
Does anyone have one they could post some pictures of?
Thanks, Doc.
Danzo
Re: 1969 rear speaker ground tab
« Reply #1 on: November 18, 2016, 12:13:26 AM »
Anyone?
« Reply #2 on: November 18, 2016, 12:27:56 AM »
Is this what you're looking for?
Danzo
« Reply #3 on: November 18, 2016, 03:24:04 AM »
Yup, whose car is that? I want to make a set.
bergy
« Reply #4 on: November 18, 2016, 11:18:44 AM »
The factory installed speakers had the ground clip permanently attached to the speaker by little "tangs" that were crimped onto the mounting hole.  The over the counter speaker "kit" had the ground clip included, but it was not pre-attached.  Here are pics of a couple of OE speakers -
« Reply #5 on: November 18, 2016, 04:22:56 PM »
Quote
Actually, I got the picture from TEAM CAMARO. It was in a thread Bergy replied to!
And since they were pre-attached to the speaker from the factory (which I didn't know. Thanks Bergy!), you'll have to find a set of 7266055 clips and crimp them to your speakers. It appears no one is reproducing them, so you'll have to find an NOS set, but sit down when you look at the pricing!! HERE'S AN NOS ONE (that's right, ONE!!!) that sold for $80.00! (see the top picture below)
And to clarify, the middle picture below is the FACTORY speaker clip and the bottom picture below is the SERVICE speaker clip.
« Last Edit: November 18, 2016, 05:25:27 PM by bertfam »
bergy
« Reply #6 on: November 19, 2016, 01:05:20 PM »
Just a thought....  The 2 original rear speakers that I have pictured are re-coned and sitting on my shelf.  If anybody needs them for their car - PM me.  No parts vendors please - just trying to help out if there is a car out there that needs them.   :-)
Danzo
« Reply #7 on: November 19, 2016, 10:03:06 PM »
PM sent.
bergy
« Reply #8 on: November 25, 2016, 12:10:11 PM »
For those who asked for the dimensions of the original ground clips, here are some photos.  Sorry they are so small - working within the limitations of the allowable size here on the site.  If you need higher resolution - PM me.
bergy
« Reply #9 on: November 25, 2016, 12:11:29 PM »
I'm sure that you already are aware of this, but here is the correct connection
Danzo
« Reply #10 on: November 25, 2016, 04:42:25 PM »
Thanks Bruce! Excellent info! Could we get a material thickness and measurements on the small ground tab side ie; corner to ground tab cut in, cut in width and length, cut in to first angle.
Thanks, Doc.
bergy
« Reply #11 on: November 25, 2016, 06:19:54 PM »
material thickness is .100" and it's spring steel.  Using the major dimensions that I gave you along with my (and previous) photos - you can scale the rest.  The bends have pretty generous radii, so precise dimensions of the faces approaching bends are difficult to get.  I don't think anyone will crawl in the trunk and complain about slight variances.
Danzo
« Reply #12 on: November 26, 2016, 03:04:21 PM »
Bruce, would it be possible to check the material thickness again? For comparison, two dimes stacked together is just a shade under.100". It seems kind of thick for this application but with the General who knows! Anything is possible.
Thanks, Doc.
bergy
« Reply #13 on: November 26, 2016, 09:59:46 PM »
oops - make it .010"   sorry
