Author Topic: Brake and Fuel lines, hoses, and clips...where to buy?  (Read 22416 times)
Re: Brake and Fuel lines, hoses, and clips...where to buy?
« Reply #30 on: May 21, 2017, 01:42:46 AM »
Just put my order in to Classic Tube. Will update comparable to OE lines when the shipment comes in. Have yet to come across any negative posts concerning Inline Tube, even had them bookmarked as first choice vendor for the lines. Just so happened the kit I dealt with last year was Classic, and I was very pleased. Might be a case of " six of one, 1/2 dozen of another"
Ended up going with OE steel to keep concurrent with the rest of the under hood detailing. My originals are still in good shape from 68, new lines should make it another 50 years! As posted/recommended, will be coating them with Sharkhide.
How is the rest of the system? Calipers, MC, hoses, etc..?  Good time to rebuild distribution block, hold off valve. And prop valve if so equipped(sub frame under driver's side door)
I'm into this brake thing now. What is Sharkhide? Could you educate me? Thanks.
http://www.sharkhide.com/sharkhide_metal_protectant.htm
jdv69z
  • 69 RS Z/28 52E
« Reply #31 on: May 22, 2017, 07:03:32 PM »
Got it. Thanks!
Jimmy V.
