The DZ engine I'm having built is nearing completion!
They called and told me that they could not get to the compression ratio I wanted with the JE/SRP pistons that I provided. What I had told them originally was that I wanted at least 11:1 CR using a modern head gasket, without a lot of head milling, and without bothering the V0820DZ stamp on the block. They didn't like the idea of decking the block and not touching the stamping. I know some of you guys have done it that way but they either couldn't or wouldn't. As assembled with the parts I provided they said the CR would be 9.9:1. I said that won't work.
I mentioned Speed Pro pistons to them and he said they are too heavy and don't use a good ring pack and I would not be happy with that setup.
He said the best way to go was with a custom set of Ross pistons, that way they could specify the dome height, etc., it's a nice light piston, and uses a good ring pack. Of course they are more money, but I said go for it because I want the engine to be right.
Here's what the Ross piston looks like:
These will give me the 11:1 cr that I want, while using a .030 MLS head gasket and minimal milling.
I'm getting excited!
