Author Topic: Rear Axle housing Decode Help  (Read 13607 times)
jim28607
« on: September 07, 2016, 01:42:28 AM »
Any Help with this Number ? located front of passenger side axle tube.
Thank You,
69 RS/SS BB 4 spd
68  RS/SS Convertable BB 4spd
Re: Rear Axle housing Decode Help
« Reply #1 on: September 07, 2016, 06:49:42 PM »
The format was used in the 70's. Probably a 10 bolt, right?
jim28607
« Reply #2 on: September 07, 2016, 10:03:08 PM »
 :-\ BOOOO, I hope not , but I will sure investigate
Thank you for your input
69 RS/SS BB 4 spd
« Reply #3 on: September 08, 2016, 12:44:56 AM »
I agree with Kurt, and will go further and state the axle was assembled on the 177th day of the year, at the Detroit Gear and Axle plant during the 2nd shift, but I'll darned if I can find any GM car that used an MC axle code!
Also, I can't tell from the picture, but is there something else stamped after the 2?
rare396bronze
« Reply #4 on: September 08, 2016, 12:58:14 AM »
1967-1969 Chevy truck 4.57 ratio. Got this out of a old Hollinder Interchange book from my old junk yard day's.
« Reply #5 on: September 08, 2016, 01:47:20 AM »
« Reply #6 on: September 08, 2016, 02:24:09 AM »
Quote
I know absolutely nothing about trucks, but did they use this format in 67-69? (ratio code - assembly plant - Julian date - shift)
« Reply #7 on: September 08, 2016, 06:29:13 AM »
Jim check the casting number on the center section. And post a pic of the rear cover if you can.
Yes MC was used for some trucks/vans in the late 60s.
Not sure about 67 or 69 but yes for 68.
http://www.gmpartswiki.com/getpage?pageid=21082
« Last Edit: September 08, 2016, 10:12:51 AM by bcmiller »
1968 Z28
« Reply #8 on: September 08, 2016, 06:05:35 PM »
It appears that in this chart the "MC" is assigned to a Series 30 (G30) heavy duty axle.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Kelley W King
« Reply #9 on: September 08, 2016, 08:08:35 PM »
I am thinking that G30 would be a 1 ton van?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
jim28607
« Reply #10 on: September 08, 2016, 08:24:20 PM »
I've definitely got some research to do , I think the axle tubes have been changed because there is diff grease leaking from both sides at the third member!!!!
Car has really wide rear tires , so I'm thinking it's been narrowed.
More pics coming  and I am great full for your input
69 RS/SS BB 4 spd
« Reply #11 on: September 08, 2016, 11:55:15 PM »
If it's what I think it is, then yes.
« Reply #12 on: September 08, 2016, 11:56:48 PM »
Possible but extremely unlikely. No reason to change tubes and if they did that, new tubes would most like have been used. A quick look at the cover will tell us a lot.
jim28607
« Reply #13 on: September 14, 2016, 01:00:52 AM »
  Here are pics of cover  and some numbers I found.
What is it?
Thanks All.
69 RS/SS BB 4 spd
« Reply #14 on: September 14, 2016, 01:15:27 AM »
Well that appears to be a late 69 and 70 passenger car 12 bolt.
Is there a casting date in the webbing area at the edge of the center section? From the rear look at the upper drivers side. Might be something like H 10 9
Go to this link and scroll down for casting date location.
http://www.camaros.org/drivetrain.shtml#axle
Look close at that stamped MC again. Could it be CMC ? With the first C spaced over a little?
