Author Topic: Help with Drive train numbers  (Read 5626 times)
jim28607
« on: September 07, 2016, 01:21:14 AM »
engine numbers any help decoding would be much appreciated
69 RS/SS BB 4 spd
68  RS/SS Convertable BB 4spd
Re: Help with Drive train numbers
« Reply #1 on: September 07, 2016, 01:43:00 AM »
It's either a 65 396 325 or a 69 427 335.
68 Ragtop
« Reply #2 on: September 07, 2016, 01:45:25 AM »
Looks like the small 6 cylinder manual trans with air conditioning code.
Assembled at the Tonawanda plant on November 27, 1966
Check it yourself here:
http://www.camaros.org/drivetrain.shtml#PadStamps
jim28607
« Reply #3 on: September 07, 2016, 01:51:51 AM »
I just came up with the 427/335, was told it was 69-427
69 RS/SS BB 4 spd
« Reply #4 on: September 07, 2016, 01:53:13 AM »
In order to find the correct application, you also need to supply the block casting number and the block casting date.
jim28607
« Reply #5 on: September 07, 2016, 02:00:03 AM »
Assembled at the Tonawanda plant on November 11, 1966
Yea I saw that too, but it is a BB, I found the 69- 427/335 or 65-396/325 on Camaro.com, was told it was 69-427
Thanks for your help.
69 RS/SS BB 4 spd
jim28607
« Reply #6 on: September 07, 2016, 02:02:36 AM »
Thanks Paul, I am going to look at that .
69 RS/SS BB 4 spd
68 Ragtop
« Reply #7 on: September 07, 2016, 02:37:29 AM »
Sorry for the mis information, but it would have helped if you said it was a big block!
JKZ27
« Reply #8 on: September 07, 2016, 10:19:04 AM »
CBTN shows LB is a 1969 427 335 passenger, 3-4 speed. Possibly the 2bbl version?
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #9 on: September 08, 2016, 10:20:47 AM »
As stated earlier, we also need the block casting number and date.
Casting number will be on the back of the block, top side of the bellhousing flange area.
