Author Topic: 1968 Camaro 327 sb crankshaft heads  (Read 3055 times)
gwp4
« on: September 02, 2016, 03:07:35 AM »
Hello fellow Camaro drivers:
I need to have the heads replaced on my 1968 Camaro 327 sb stock engine.  The original engine shop that did the work on the car machined the heads incorrectly (crooked) and the bore for the valve stem is off slightly.  I want to keep the engine as stock as possible.  Would Edelbrock heads be as close to stock or are GM heads better?  Really open to suggestions/recommentations.  Many thanks.
Re: 1968 Camaro 327 sb crankshaft heads
« Reply #1 on: September 03, 2016, 10:41:59 AM »
Wouldn't it seem fair to have the shop that did the bad work replace them for you?
If you still want the stock look, there are heads out there. Check your local craigslist or swap meets.
If you want, let me know what dates you are looking for and I can check around.
