Author Topic: Attaching Vinyl Top  (Read 4336 times)
Daspots777
Attaching Vinyl Top
« on: August 27, 2016, 05:43:17 PM »
I'm having trouble locating the metal pegs/studs, whatever they're called, to attach the trim piece/keeper for my vinyl top. I am missing about half of them and can't seem to find anyone that has any. Thanks!
Re: Attaching Vinyl Top
« Reply #1 on: August 28, 2016, 04:16:13 PM »
Eastwood (among others) sells the stud guns and trim rivets for attaching trim like the factory did with a welded stud. Used the same for window trim clips -
You can buy the rivets as replacements from them, and/or buy the whole system. Comparatively easy to handle - see the website link below that shows the stud detail (with the approximate clip in the pic).
http://www.eastwood.com/stud-welder-trim-rivet-tip.html
ban617
« Reply #2 on: August 30, 2016, 05:43:12 AM »
    If your car is already painted , you should be able to get ones that screw in just drill a small hole & screw them in ... Most body shop supply places have them or can get them ...
Daspots777
« Reply #3 on: August 31, 2016, 01:28:39 AM »
Excellent, that gives me somewhere to start.
Thanks to both of you!
69 Zee
« Reply #4 on: September 09, 2016, 12:36:18 AM »
Here's a previous thread by HawkX66 (Dave) another member.  Discussing the stud placements as well as a stud gun tip (home made).
http://www.camaros.org/forum/index.php?topic=13894.msg120737#msg120737
Also just for future reference, try using the search window at the bottom right of CRG's home page (showing the 3 Camaro's) as an overall search.  Or in the forum section each "Group Discussion Topic" will also have a search window at the top right.
Ex..discussion forum "Originality", type Vinyl top rivet
Hope this helps
Darrell
