Author Topic: 69 SS battery cable clip?  (Read 7601 times)
Ejam
« on: August 16, 2016, 07:41:48 PM »
Does anyone sell the 2 clips for the positive battery cable that are riveted to chassis? Also the oil pan clips for cable? 69 SS 396/325 auto car
Re: 69 SS battery cable clip?
« Reply #1 on: August 16, 2016, 07:47:00 PM »
Yes, both types are on eBay.
Ejam
« Reply #2 on: August 17, 2016, 06:11:23 PM »
Ok bought the cable clips but how do you install them? They seem to need to be riveted somehow
« Reply #3 on: August 17, 2016, 09:10:55 PM »
 You should be able to insert the clips into the hole easy enough and then use something like a nail counter sink tool that has a tapered shape and insert it and tap with a mallet lightly and that should expand them internally to lock it. Maybe a screw driver that just fits into the inside of the clip will work.
« Reply #4 on: August 17, 2016, 09:13:57 PM »
If it is a hollow tube yes it will need to be expanded in order to make it remain in place.
Chick - 68camaroz28 -  illustrated his process a while ago. search under user name 68camaroz28 and search his posts.
« Reply #5 on: August 17, 2016, 09:17:52 PM »
 It should be hollow, sort of like the fuel and brake clips.
m22mike
« Reply #6 on: August 17, 2016, 10:40:11 PM »
The repo frame clips are a rip, total junk. Good luck using them, nothing like the originals.
« Reply #7 on: August 18, 2016, 02:00:56 AM »
Hi James!
Discussed here in my build thread. http://www.camaros.net/forums/133-build-projects/182584-time-another-68-z-28-restored-46.html
What I wrote and did- "I finally found what I thought worked great for securing this clip, a threaded rivet. The threaded rivet has a size that is just about exact to the brass one in the repro battery cable clips. Just take out the repro clips type rivet, and replace it with one of the alum. threaded rivets. I painted the threaded rivet black for a nice match. Only minor issue involved the arbor on the threaded rivet installation gun as its too big to fit thru the rectangular slot in the clip but that was easily fixed by drilling four (4) #6 nuts to a larger I.D. and using them to fill the gap enabling a tight fit so the crimping could be completed. Very easy and it worked great. A little touch up and ready to go."
« Reply #8 on: August 18, 2016, 04:07:18 PM »
A rivnut insert.
« Reply #9 on: August 18, 2016, 08:33:25 PM »
m22mike
« Reply #10 on: August 19, 2016, 01:59:04 AM »
Very good Chick.
