Author Topic: Removed Muncie  (Read 8247 times)
hihorse
Removed Muncie
« on: August 16, 2016, 07:37:49 PM »
removed the M20 from my 69  396/325HP 12B X66 car. Are the flywheel bolts (letter P in middle) original?
hihorse
Re: Removed Muncie
« Reply #1 on: August 16, 2016, 08:00:21 PM »
heres the bellhousing from the car
hihorse
Re: Removed Muncie
« Reply #2 on: August 19, 2016, 07:04:10 PM »
driveshaft
hihorse
Re: Removed Muncie
« Reply #3 on: August 19, 2016, 07:06:16 PM »
rough weld
Re: Removed Muncie
« Reply #4 on: August 19, 2016, 07:08:50 PM »
Do you see any hint of stripes on the driveshaft?
And can you do an accurate measurement of the driveshaft (measure from the center of one universal joint to the center of the other universal joint).  It usually is easiest to do that if you have help.
I can't help with the flywheel bolts.
« Last Edit: August 20, 2016, 01:09:21 AM by bcmiller »
jdv69z
  • 69 RS Z/28 52E
Re: Removed Muncie
« Reply #5 on: August 20, 2016, 11:59:36 PM »
I don't know  on the flywheel bolts, but I'm guessing original, only because I don't know any hardware stores or anywhere else where one would buy bolts marked like that.
Jimmy V.
Re: Removed Muncie
« Reply #6 on: August 21, 2016, 11:50:33 PM »
That's a lot of balance weights. I don't recall seeing the washer style weight before....
Re: Removed Muncie
« Reply #7 on: August 22, 2016, 12:31:04 AM »
That does not look like a factory weld.  I would venture to say there was a repair and a rebalance in its life.
Like the rallye green and short spoiler.
Re: Removed Muncie
« Reply #8 on: August 22, 2016, 02:10:02 AM »
X2
X33RS
Re: Removed Muncie
« Reply #9 on: August 22, 2016, 02:50:54 AM »
The washer, I commonly see from the local driveshaft shop here when building or balancing shafts, tacked on exactly like that.
Re: Removed Muncie
« Reply #10 on: August 22, 2016, 11:18:07 AM »
Upon further study of the picture of the whole shaft, I wonder if the previous owner or a shop was convinced that something was amiss since the yokes are/were clocked in an odd way as the other DSs discussed elsewhere on this site? For whatever reason, it is apparent that this driveshaft is not 'clocked' like the others now. Either it was clocked in its current configuration when repaired or it was one of those, it's not broke, but I gotta fix it scenarios?
hihorse
Re: Removed Muncie
« Reply #11 on: August 22, 2016, 03:21:58 PM »
i didn't see any  hint of the stripes. Driveshaft measures 49.5"
hihorse
Re: Removed Muncie
« Reply #12 on: August 24, 2016, 05:15:04 PM »
is cover correct?
