More pictures of the engine compartment:
Look at the difference in the captured washer on the lower fender bolt from the right side to the left side.
Radiator Tag with the white highlighted UH.
Spring painted black-
All of the B, P, & B stampings are in green.
Note the paint on the by-pass hose coupling. From other vintage pictures I have from other cars it shows the by-pass hose was in place when the engine was painted.
RS Washer bottle zinc screws.
Clearly shows the 3/4” captured washer used on the hinge to fender which is not what the 68 AIM calls out. Very normal process of what was actually used.
Radiator Cap-
Fan Shroud bolt assembly-
