Author Topic: RPM rust preventer  (Read 2931 times)
john302
RPM rust preventer
« on: August 02, 2016, 08:57:12 PM »
Has anyone used the RPM rust preventer paste? good,bad,ok   thanks
Re: RPM rust preventer
« Reply #1 on: August 02, 2016, 09:26:39 PM »
 I use it a lot and if done right it does work effectively.
I pre-heat the parts to about 150 degrees and then apply RPM with a short bristle paint brush.
The method is to work RPM into the surface when in a semi-liquid state before it cools and solidifies.
I put it on thick then when cool I use a rag to wipe it down to take the excess off.
