Author Topic: 69 Z Fuel Pump  (Read 5049 times)
sixt9x33rs
69 Z Fuel Pump
« on: August 01, 2016, 01:53:14 AM »
Guys,
I believe the FP in my Z is going bad. Is there a certain one that you guys would recommend?
Lawrence
Re: 69 Z Fuel Pump
« Reply #1 on: August 01, 2016, 09:47:58 PM »
I've heard many aftermarket pumps are defective, putting out 10 psi.
GM Performance sells a street performance pump, #6415325. Has a 7 psi shutoff and is rated at 30 gph. Doesn't quite look OE but aftermarket pumps don't either.
sixt9x33rs
Re: 69 Z Fuel Pump
« Reply #2 on: August 01, 2016, 09:57:12 PM »
Thanks William will check it out.
Re: 69 Z Fuel Pump
« Reply #3 on: August 02, 2016, 02:43:25 AM »
Bought mine at Napa - make sure you get the Made in USA pump. They must have demilled the pressure die cast mold - you can still see the "GM" casting outline on the side of the pump housing. Looks right, fits and works perfectly, just doesn't have the GM logo.
Just my $.02 -
Fred Mertz
Re: 69 Z Fuel Pump
« Reply #4 on: August 18, 2016, 04:50:37 AM »
I recently had a fuel pump from NAPA auto parts.  I was having drivability problems along with a gas smell when driving a highway speeds.  It turned out to be the fuel pump. I put a pressure guage on it and it read 9.5 lbs. of pressure.  I solved the problem by adding a regulator. I mounted it to the front of the cylinder head using one the accessary holes.
