Author Topic: tach number  (Read 18292 times)
77-chev
tach number
« on: January 04, 2007, 12:24:23 AM »
trying to find out wich tach came in 67 rs/ss, ink number is stamp on back of tach plate.tach guts are gone
Jerry@CHP
Re: tach number
« Reply #1 on: January 04, 2007, 02:18:09 AM »
350 engine, 5K redline, 396-325hp engine, 5500K, 396-375hp, 6K redline.
There were tach shortages are the LA plant and many cars did not get the correct tach there.
Jerry
77-chev
Re: tach number
« Reply #2 on: January 04, 2007, 05:45:42 PM »
thank you , she was bulit in norwood 4 week in sept, there is a ink stamped # on back of what is left of tach.6468244
lakeholme
  • 68-12D L30/M35
Re: tach number
« Reply #3 on: January 04, 2007, 11:13:19 PM »
When you say stamped on the back, exactly where (what plate)?  Is it the head assembly?
FYI, according to the P&A the 67 Camaro Tach Assembly w/console guages (350, 396) was stamped 6468910 (or 6468696 -first design).  It literally says that "(stamped 6468910)".  Ed or someone with more P&A understanding could help.  (And yes, not all p/n from the P&A were the same as what was on the actual part.)
« Last Edit: January 05, 2007, 12:48:51 AM by lakeholme »
77-chev
Re: tach number
« Reply #4 on: January 04, 2007, 11:24:13 PM »
rear axle # pw1006g or the w looks like it got stamped up side down and could be a m.cast # is 3894859,# on the rinmg and pioin big gear is 2 gm 3910823 15 41 9 66 still try to find out it if it is rs ss. speed-o cable was out before i know,will look at pic.Looks like factory duel mufflers hangers bolted to car.# on dash cluster 6457943,speedo 6457926[n]-w.motor turn out to be 62-65 327,tran's is 68 muncie m-21.agian  ink # on tach back is 6468244 thank you
77-chev
Re: tach number
« Reply #5 on: January 04, 2007, 11:33:22 PM »
thank you for info. the # is on the plate  that the tach mounts to.the plate cones off with 3 screws
Re: tach number
« Reply #6 on: January 05, 2007, 12:00:45 AM »
Group 9.750 Tachometer Assy
67 Camaro w/console gauges (327), (1st design) - 6468244 (stamped 6468244)
15-41 ring and pinion is a 2.73 ratio and the PW verifies this as being a 2.73 10 bolt open rear end, assembled on October 6th, 1966. This is further verified by the casting number (3894859). The date on the Ring and Pinion of 9-66 (September, 1966) matches the stamped date (1006), so it's probably original to that housing. However, your 09D assembly and the October 6th axle dates don't really line up very well. However, if your car was started late in the week, it's possible you could have gotten an October 6th rear end. Here's the 1967 Calendar and you can see that the last day of 09D was either the 29th or 30th (depending on if they worked a Saturday that week), and October 6th is the next Friday, so it's possible, but it would still be hot as they were installing it!!!
Your car isn't an SS, so it's either a 327/210 (base engine) or a 327/275 (L30). The 68 Muncie or course isn't original to the car, but what's the numbers on it? (I'm missing mine!!)
Check your Trim Tag and post the numbers. We should be able to narrow it down for you.
« Last Edit: January 05, 2007, 12:12:34 AM by bertfam »
77-chev
Re: tach number
« Reply #7 on: January 05, 2007, 01:25:29 PM »
bertfam thank you very much,# on tran's is p8s06 18n344620. Other clue is there is no emblems below camaro emblem on front fenders[no hole's look to be factory fenders] tag # are 09d 67-12637 nor 10181 d body 742-z r-2 2lg 3sl 5y. I think a good ideal would be to have crg listed with anybody try to sell a camaro on ebay. thanks agian 77-chev
Re: tach number
« Reply #8 on: January 05, 2007, 03:33:28 PM »
Thanks for the Muncie info. Not mine but it IS from a Camaro, so maybe it's someone elses.
Your car was equiped with the following options:
742Z - Red Deluxe Bucket Seats
R2 - Bolero Red exterior with a black vinyl top
2LG - 4 Speed floor mounted Transmission with Center Console
3SL - Z23 (Deluxe) Interior and Z22 Rally Sport option
5Y - Custom Shoulder Belts
Thanks again for the numbers
Steve68
Re: tach number
« Reply #9 on: January 06, 2007, 02:35:37 AM »
Group 9.750 Tachometer Assy. - Tachometer Unit - Lamp Assy. - Bracket
67 Camaro w/ front compartment instr.cluster 6468244
                Tachometer Unit (8 cyl.)                987099 (Removed from service November 69)
                 Lamp Assy. (8 cyl.)                     3906189
                 Bracket (8 cyl.)                          3906157
lakeholme
  • 68-12D L30/M35
Re: tach number
« Reply #10 on: January 06, 2007, 04:47:49 PM »
Steve,
Which P&A did you take that from?
Steve68
Re: tach number
« Reply #11 on: January 06, 2007, 04:53:51 PM »
Phillip
It's from my October 66 one.
77-chev
Re: tach number
« Reply #12 on: January 06, 2007, 07:23:27 PM »
when we were taking the 327 out of car we had one hell of a time getting the motor mont bolts out.started looking at motor frame mount, there are bb mounts and they look to be never touch.i red somewere that only ss model came with shouder belts,5y belts all deluxe .Muffler hangers are stock for duels. car did sit higher than norm in front. clamps for speedo cable are on pass side.still diging this poor car has been to one ugly butcher shop
lakeholme
  • 68-12D L30/M35
Re: tach number
« Reply #13 on: January 06, 2007, 10:42:24 PM »
77-chev,
Hang in there!  There are a lot of us un-doing other folks car butchering out here.  In the long run, it's a noble deed... and fun!
Steve,
Thanks! By Oct. of 67 it reads like Ed posted above.  I'm still trying to fathom all the ins and outs of GM P&As.
Steve68
Re: tach number
« Reply #14 on: January 07, 2007, 02:58:56 AM »
I thought he had an early production car and I was trying to get back to as close to "original" as possible on the part numbers as I could for him.........if that's not the case then my bad.  My October 67 has 5 different listings for console gauges but only 2 are for the 327 (Not a SS - see ED's note above).  They are: 1st design 6468244 and 2nd design 6468909 (stamped same #).  The Tach & Lamp Assy's along with the Bracket numbers are the same as I listed above.  I believe Ed's P&A is a Sept 68.
