Author Topic: AMK B-11842  (Read 7203 times)
Danzo
AMK B-11842
« on: July 26, 2016, 02:35:43 AM »
Looking for a 1/4 x 3/4 bolt with rbw head markings. The number listed above is from AMK but of course they have a $30.00 minimum. Anyone have another source? Thanks in advance.
Re: AMK B-11842
« Reply #1 on: July 26, 2016, 02:53:40 AM »
 What's the GM number -or- AMK page number?
I'll check my box of bolts.
Re: AMK B-11842
« Reply #2 on: July 26, 2016, 03:06:19 AM »
 I found it. It looks like a valve cover bolt? I have one in my hand and though it has RBW it doesn't have the 3 lines on the face. I've seen many valve cover bolts with and without the 3 lines. Do you need the lines?Also, the zinc plating is worn from age.
Danzo
Re: AMK B-11842
« Reply #3 on: July 27, 2016, 01:35:43 AM »
Mike, thanks for the very generous offer. I am looking for a complete set. Talked to Camaro Specialties today and they think they can help.
ban617
Re: AMK B-11842
« Reply #4 on: July 27, 2016, 05:10:55 AM »
There is a guy that sells original hardware on The Super Car Registry board ...in the classified section.....
Rick68
Re: AMK B-11842
« Reply #5 on: August 03, 2016, 10:32:24 PM »
Are they valve cover bolts?If so I have a complete set that I bought from Heartbeat City that I did not use.They have the RBW markings with no lines.It also comes with the valve cover holdowns.The part # is EGB-1938.
Danzo
Re: AMK B-11842
« Reply #6 on: August 03, 2016, 11:11:51 PM »
I believe those bolts are 1/4 x 1/2"
Re: AMK B-11842
« Reply #7 on: August 04, 2016, 02:06:45 AM »
If you are looking for some original bolts or replacements, it would help if you told us the original application.
Danzo
Re: AMK B-11842
« Reply #8 on: August 05, 2016, 12:28:28 AM »
1969 396 325hp. I am running thicker valve cover gaskets hence the need for the 3/4" length vs 1/2".
Thanks, Doc.
Re: AMK B-11842
« Reply #9 on: August 05, 2016, 09:32:52 PM »
Why thicker gaskets?
Danzo
Re: AMK B-11842
« Reply #10 on: August 06, 2016, 11:08:59 PM »
Higher quality gasket.
