Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
Muncie 4 speed questions
« previous
next »
Print
Pages: [
1
Author
Topic: Muncie 4 speed questions (Read 5633 times)
Butchie7284
Newbie
on:
July 10, 2016, 02:25:03 PM »
Hey guys! So I located a Muncie for the 68 ss350 I'm restoring and I recieved all of these numbers from the gentleman that has the trans.
P8E09-date stamp
3925660-main case number
28P313836-vin stamp number?
3884865-side cover number
93329-tag number on side cover bolt
3915401D-hurst shifter competition shifter base.
Two questions... Can I get the hurst 68 camaro linkage rods and shifter handle to work with this base mechanism? Also the tag number. i can't seem to find any info on the 5 digit tag number. Anyone know what the 93329 decodes?
Tweet
Logged
Hero Member
Re: Muncie 4 speed questions
Reply #1 on:
July 10, 2016, 03:21:10 PM »
It's a Muncie M20 from a 1968 Pontiac GTO assembled at the Pontiac, MI plant. The transmission was assembled on May 9th, 1968. The tag number is actually 9793329 but the mounting bolt probably obscures the 97.
Logged
Butchie7284
Newbie
Reply #2 on:
July 10, 2016, 10:43:07 PM »
Awesome! Thank you!
Logged
Kelley W King
Hero Member
Reply #3 on:
July 11, 2016, 07:44:19 PM »
Ask and you shall receive on CRG
Logged
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
rare396bronze
Member
Reply #4 on:
July 13, 2016, 01:23:34 AM »
Check what side the speedo gear is coming out. I have one coded for a 68 Pontiac that comes out of the drivers side. Camaros come out the passenger side.
Logged
CRG Member
Reply #5 on:
July 13, 2016, 02:41:18 PM »
The transmission posted most likely has the 3846429 casting number tail housing - with drivers side speedometer.
First generation Camaros used the 3857584 tail housing - with the passenger side speedometer.
This is not a big issue, it will still work fine.
Logged
Bryon
/ 1968 Camaro SS 396 coupe - now old school 468 big block
Butchie7284
Newbie
Reply #6 on:
July 14, 2016, 02:10:22 AM »
This trans actually fell through so I sourced another one. Better shape and cheaper!
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
