You may have that if timing isn't tweaked.
Mine was the same way, even with the stock 30-30 cam. Plus living at 5,000 ft where the engine doesn't make quite as much vacuum compounds the problem. The fix is to run more initial timing, limit the centrifugal, and run your vacuum advance to manifold vacuum source for a bit extra timing at idle, then adjust the carb accordingly. Once setup properly the engine will produce 3-6 inches more vacuum.
For example on mine, up here at this elevation with stockish timing settings and the vacuum advance hooked to ported on the carb, my engine only made 5 inches. Not enough for brakes. One good stop was all it had.
I ended up soldering the centrifugal advance slot to limit that to 16 degrees. I set my initial timing at 20 degrees (together 36 total) I then dialed in vacuum advance with a limiter screwed down to the rear arm on the breaker plate made out of a penny. Old trick as they don't sell the limiter plates anymore that I can find. Making one out of a penny takes 2 minutes. I limit the vacuum advance to about 12 degrees this way and then run it directly to a manifold source to add 10-12 degrees to idle timing. So technically the idle timing is about 30-32 degrees (initial plus vacuum together) This added timing goes away however as soon as you step on the gas and vacuum drops, and you centrifugal takes over when under load. At light throttle cruising with everything together you end up with 45-47ish timing give or take while cruising, which works perfectly, good drivability and better gas mileage. Works fine at 11:1 with the 30-30 cam on pump gas.
This is how I set up most distributors for customers that have large overlap camshafts, as it tends to smooth the idle a bit, makes carb tuning a bit easier, and helps the engine produce vacuum. With a 140 cam in a little 302 it's going to need tweaks like this for best drivability.
With these tricks my engine is now making about 12 inches of vacuum up here at 5,000 ft which is plenty for power brakes. It stops just fine now.
Hope that helps.
