Author Topic: 250 6 & tremec 5 speed.What clutch?  (Read 5891 times)
HustleRussell
« on: July 08, 2016, 12:43:21 AM »
Just pulled a 250 from 72 Ventura. Would like to give it a test run in 68 rs. I've got a tremec 5 speed with 26 spline input shaft. The clutch from the 250 is 9.0" and 10 spline & the pressure plate measures 10.2". Does anyone make a clutch for this application? thanks.
Russ
68 RS
69 SS
HustleRussell
Re: 250 6 & tremec 5 speed.What clutch?
« Reply #1 on: July 18, 2016, 08:14:25 PM »
Got a clutch for 1996 s10. Diameter is 9.125 and 26 splines.
Russ
68 RS
69 SS
« Reply #2 on: July 19, 2016, 12:31:02 PM »
This sounds like it could be a great cruising combo for the straight 6..  Keep us posted on how it runs.
