Author Topic: 1969 TH400 modulator line bracket  (Read 7331 times)
Danzo
« on: June 14, 2016, 12:17:18 AM »
Does anyone have a picture of an original 1969 TH400 modulator line? I am trying to see what the attaching bracket looks like. Thanks in advance.
Danzo
Re: 1969 TH400 modulator line bracket
« Reply #1 on: July 05, 2016, 10:35:44 PM »
Anyone?
WorkinProgress
« Reply #2 on: July 06, 2016, 01:53:33 AM »
Where exactly is the bracket located to hold the line in place? I can probably help you out, but need to know what I am taking a picture of.
        - Warren
« Reply #3 on: July 06, 2016, 03:03:48 PM »
The dipstick tube and vac modulator line have integral brackets secured by one of the trans/engine mounting bolts.
It's noted in the assembly manual, Section M40 pages A4 & A5.
« Last Edit: July 09, 2016, 01:02:42 PM by william »
Danzo
« Reply #4 on: July 17, 2016, 11:06:55 PM »
Warren any luck? Thanks, Doc.
Danzo
« Reply #5 on: July 21, 2016, 12:41:12 AM »
Guys, this is the line in question. All of the repops seem to be missing the bracket. Does anyone know how this bracket was originally attached and how to duplicate the process? Thanks in advance.
http://www.ebay.com/itm/262369578762?item=262369578762&viewitem=&vxp=mtr
Camarocards
« Reply #6 on: July 21, 2016, 03:19:28 AM »
Here is a picture of a '68 TH400 modulator line bracket. It's attached to the tube with three spot welds.
Bob
Bob
'68 SS L35 01D
Danzo
« Reply #7 on: July 21, 2016, 11:46:28 PM »
Bob, would it be possible to get some measurements off of that bracket? I think it would be pretty easy to make.
Thanks, Doc.
Camarocards
« Reply #8 on: July 22, 2016, 03:18:29 AM »
Doc,
Sure. No problem. Give me a day or two and I'll post some dimensions.
Bob
Bob
'68 SS L35 01D
Camarocards
« Reply #9 on: July 26, 2016, 02:51:50 AM »
Doc,
Here are some dimensions for the modulator line bracket. Hope it helps. Let me know if you need any additional info.
Bob
Bob
'68 SS L35 01D
Danzo
« Reply #10 on: July 27, 2016, 01:33:56 AM »
Bob that is perfect!Thank you very much!
