Author Topic: 327 or 350  (Read 9757 times)
68badmaro
327 or 350
« on: June 13, 2016, 06:30:32 PM »
Hey there everyone! New member here to the group. I have a question about my recent "68" purchase that came with a SBC and 4 speed Sag. I was told by the seller the block installed is a 350 and it is the original block equipped on this car. Not sure how true this is. No heads on the engine just the short block. Casting numbers are..
#F1014HF  (pass side pad stamping)
#3858174 (Rear left side casting)
Online decoding charts give me both, a 327 and 350 for F1014HF stamping and 3858174 casting there is blogs about this being a mystery block possibly a 327 or 350 out of some corvettes. Is there any other indications on the block I can use to decipher? I'd like to keep this block and rebuild it if possible especially if its matching numbers. Any help is greatly appreciated.
Re: 327 or 350
« Reply #1 on: June 13, 2016, 06:38:05 PM »
Casting number and HF application code indicate a 327. Either from a 65 or 66 full size Chevrolet.
Re: 327 or 350
« Reply #2 on: June 13, 2016, 06:57:17 PM »
Welcome to the site. Post some pics of your new purchase (please)
Re: 327 or 350
« Reply #3 on: June 13, 2016, 07:33:25 PM »
I think your car would have to be an SS to have a 350.
68badmaro
Re: 327 or 350
« Reply #4 on: June 13, 2016, 07:33:52 PM »
Thanks for the info. Here are some pics of the first day I brought it home.
68badmaro
Re: 327 or 350
« Reply #5 on: June 13, 2016, 07:42:14 PM »
So that sums it up better. I suspected the block was not matching for 68. Could the block possibly have came out a Corvette?
Re: 327 or 350
« Reply #6 on: June 13, 2016, 07:49:03 PM »
Great pics. What are your plans for it? Stock colors per the trim tag, or a different color in mind? Wheels?
68badmaro
Re: 327 or 350
« Reply #7 on: June 13, 2016, 08:00:36 PM »
Thank you. Stock Tag color is Teal Blue with Black standard interior, 4 speed trans and V8. I think I will go either Teal blue or custom Black with the louver hood and RS grille. Havent decided what engine most likely will start with a Gen1 small block and with a M20 Wide Ratio. Later will look into going LS. Already has a 12 bolt posi not sure if original but I am definitely content with keeping that! On the wheels I love the gunmetal American Racing Torque thrust wheels on 15 BFG's...Just never get old for me. Im more of an old skool guy :o 8)
Re: 327 or 350
« Reply #8 on: June 13, 2016, 08:18:07 PM »
No the block is from a full size car like an Impala.
What is code stamped on the front edge of the passenger side axle tube? And how does it compare date-wise to the build week on the trim tag on the firewall?
Re: 327 or 350
« Reply #9 on: June 13, 2016, 09:14:08 PM »
If it has a factory 12 bolt, (dates line up), would that indicate it may have been a factory SS?
Could you get a LM1 or plain jane car with a 12 bolt, and not have an SS, Z, Dealer super car?
(Sorry 68 guys, I am not well versed)
Re: 327 or 350
« Reply #10 on: June 13, 2016, 10:14:05 PM »
It's OK Austin.  Yes, an original 12 bolt in a 68 is a good sign of an SS or Z28.  The L30/M20 combo also got a 12 bolt. There wasn't an LM1 option in 68.
In 67, there were even some 6 cylinder cars that got 12 bolts.  They were installed when the 10 bolt ratio was not available or a heavy duty axle was ordered.  I personally know of 2 cars that were that way.
Fixed typo
« Last Edit: June 14, 2016, 12:41:55 AM by bcmiller »
dale_z28
Re: 327 or 350
« Reply #11 on: June 14, 2016, 04:40:06 PM »
If it's a 327, slap a 283 crank in it and wind 'er up!
'69 X33 02D   Since 11-29-'77
~Ben Franklin
jdv69z
  • 69 RS Z/28 52E
Re: 327 or 350
« Reply #12 on: June 15, 2016, 12:36:02 PM »
But don't forget to change pistons as well!  ;D
Jimmy V.
Re: 327 or 350
« Reply #13 on: June 15, 2016, 02:42:44 PM »
The old 301 was a 283 bored out to 4 inches.
There is more to making a legitimate 302 than a 327 block and a 283 crank. A properly build 327 will rev almost as good as a 283 or 302. And if both (327 and 302) have similar compression, same cam, similar ported heads, and good rods - which do you think would be faster? :)
Re: 327 or 350
« Reply #14 on: June 15, 2016, 02:48:44 PM »
No replacement for displacement.
