Author Topic: Silver 69 Z28  (Read 127908 times)
dale_z28
Re: Silver 69 Z28
« Reply #75 on: June 17, 2016, 11:36:46 PM »
Steve, your last picture of the three - a few posts above - the left front corner of the gas tank appears to have a "dimple". Is this a tank drain? My car is also a 2D and my tank, to the best of my knowledge, is original (I bought my car with 57k in '77, no reason to suspect it's replacement). It has this drain, which I am very curious about.
That is just a dent. I haven't verified the tank date. I suggest that you verify the tank date. The drain may have been added at some point, but not from the factory.
I've got pics t post of my tank date and the drain, I'll find the thread and get them on this weekend the tank is dated 28 69
'69 X33 02D   Since 11-29-'77
~Ben Franklin
Steve Shauger
    • Vintage Certification
Re: Silver 69 Z28
« Reply #76 on: July 14, 2016, 01:56:12 PM »
OK, back to Steves great car!
I assume since the radio, was mentioned as a dealer install, they would have had to drill the fender, wire up the speaker, and install the deck. I also assume the original owner brought the vehicle back for the motor bracket and cable, for the recall. Just curious since I have a large stack of my own invoices, if the original owner made continual visits to the dealership on a regular basis to see the car stayed in tip top shape or if it sat parked for a long duration of time? It seems that most of these original cars fall into one of these categories.
The radio was installed by the dealer and is listed as added on the invoice for $61.10. Interestingly enough it is a Motorola radio, that looks almost identical to the Delco. The radio brace was installed and the speaker is also similar. I wonder if there was some kit available. Regarding the antenna the dealer installed that as well.
Steve Shauger
DarrenX33
Re: Silver 69 Z28
« Reply #77 on: May 18, 2021, 03:06:19 AM »
Steve. Wondering what front spring tags were on this car?
1969 Z28 Rallye Green X33/M22/4.10
1972 Corvette
Charley
Re: Silver 69 Z28
« Reply #78 on: June 28, 2021, 04:39:18 AM »
I have the car in Az. When I get back down there I will try to look.
Charley
Re: Silver 69 Z28
« Reply #79 on: July 15, 2021, 07:12:26 PM »
3955720
DarrenX33
Re: Silver 69 Z28
« Reply #80 on: August 14, 2021, 09:52:35 PM »
Thanks a lot Charley!
1972 Corvette
