Author Topic: ?? 9N35203 ?? - Z28 Engine  (Read 6802 times)
« on: June 02, 2016, 07:59:34 PM »
Your 302cid/290hp Z28 engine is on eBay...
Engine pad is stamped: V0514DZ
Block casting number: 3970010
Seller id: junkman60
Seller location: Monroeville, NJ
http://www.ebay.com/itm/1969-CAMARO-Z28-DZ-302-ENGINE-block-1178-crank-186-heads-472-intake-DZ303-69-rs/291777621299?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36861%26meid%3Dd38211a5d77d44ea874552df7ff161de%26pid%3D100011%26rk%3D6%26rkt%3D10%26sd%3D351746167189
Listing description...
"Here is a used 1969 Camaro Z28 DZ 302 engine . This is not made up restamp like many of them are out there . This was part of an estate of muscle car parts I bought out a short while back .I sorted out all the parts and put everything I had for it with this lot .  None of these parts have been checked other than a normal visual check that I do looking for obvious damage  which I couldnt find any signs of  .
All parts will require reconditioning or maching as required .
The block  is stamped V0515DZ ,  #010 casting . Bored +.030 . The vin back by the oil filter is very hard to read , but as best I can read it is as follows . 9N35203 . Thats all the more of it I can see .
The heads must have been replaced at one time . They are the correct #186
 , 2.02 heads but the dates are off a bit . E219  &  I159 .
Intake manifold #472 looks unmolested
Carburetor #4053 / 902 is correct , but the date is off .
#1178 crankshaft ,
Correct harmonic balancer & timing chain cover
10-1/2" flywheel
8 Connecting rods & +.030 pistons
I do not have any of the other parts for this engine . All sold as is ."
Re: ?? 9N35203 ?? - Z28 Engine
« Reply #1 on: June 02, 2016, 08:19:26 PM »
Looks like the makings for a 'nearly' complete 302 engine..  BUT... someone tore it down for a reason...?  I would wonder what the reason was.. :)
« Reply #2 on: June 03, 2016, 01:54:15 AM »
Partial VIN makes no sense.  There should be a 6 after the N.  I would want to see better pics before I spent a dime on the block.
« Reply #3 on: June 03, 2016, 02:48:21 AM »
For the money sought, one would think that the seller could afford a lighting device, camera lessons and the ability to see. Even my old eyes , with as bad as the pictures are, see a build date as the 14th and not as claimed by seller, 15th?  I could see other numbers, but frankly, why should I waste time looking if the seller dosen't care?
« Reply #4 on: June 11, 2016, 02:09:21 PM »
I think the VIN would be N65203X which would line up nicely with an 0514 build date.
« Reply #5 on: June 21, 2016, 09:24:45 PM »
6-20-16: "This listing was ended by the seller because there was an error in the listing."
