Author Topic: How to tell if console gauges are original to car  (Read 15105 times)
Re: How to tell if console gauges are original to car
« Reply #15 on: June 02, 2016, 03:06:00 AM »
additionally, another small feature is checking the console itself.  Look for the cutout on the lower front half of the console, and check the lower console mounting bracket to see if the guage wiring harness bracket and plug socket are there.
An interesting point was raised on the console bases and wiring harness details in the AIM by Chick during his 68Z build thread over at Team Camaro. The theory is that no '68 consoles had a cutout in the front, nor a console bracket with the harness clip, but that in '69, all brackets had the harness connector clip, and a forward cutout. This is irrespective of the console having gauges or not.
Since that was raised as a possible theory, I have looked at every 68-69 console on eBay, CL and at swap meets, and have never seen a 68 console (off-white plastic, viewed from beneath) with a cutout, nor a 69 (black plastic) without a cutout.
« Reply #16 on: June 12, 2016, 04:07:34 AM »
I never realized it was a question.
I know that as the difference between 68 and 69 parts.
« Reply #17 on: June 12, 2016, 11:43:28 AM »
The 68 vs 69 console details? Good to know that is indeed a confirmed difference then, thanks Kurt!
« Reply #18 on: June 12, 2016, 01:32:28 PM »
Yep, and the console plate that holds the seat belts for the shoulder harness is painted black. :)
