Author Topic: Rad Tag Decode  (Read 13052 times)
LVN 67
  • John 67 NOR 02E L-35/T400, 6th Owner
Rad Tag Decode
« on: May 23, 2016, 06:00:41 PM »
I'm helping a friend with some work on her Camaro. Its a 69 with a non original 350. Took out the radiator to be serviced and noticed it was an original one. The car has no trim tag on it, but its an early 69 N501365.
    Tag shows the following:
    IA  VL
    CF
    59
  There are no numbers on the bottom of the tag. I'll try and get a picture posted.
   Any decode help would be appreciated.
Re: Rad Tag Decode
« Reply #1 on: May 23, 2016, 06:12:13 PM »
I think IA and CF are the tank codes. So far I can't find a VL radiator application. Not likely that it's original. Might be from a Nova.
See this link.
http://www.camaros.org/coolingsystems.shtml#tag
Re: Rad Tag Decode
« Reply #2 on: May 23, 2016, 07:42:59 PM »
You posted this 3 times. I removed the other duplicate posts. Yes please post pics when you can.
LVN 67
Re: Rad Tag Decode
« Reply #3 on: May 23, 2016, 11:38:47 PM »
Here is a picture of the tag.
Re: Rad Tag Decode
« Reply #4 on: May 24, 2016, 04:00:52 AM »
I'd guess it's a Nova rad.
What's the numbers stamped on the bottom edge of the tag? They will be smaller (see the article for examples).
LVN 67
Re: Rad Tag Decode
« Reply #5 on: May 24, 2016, 11:25:42 AM »
Here is another tag picture, no numbers on the bottom.
Re: Rad Tag Decode
« Reply #6 on: May 24, 2016, 02:42:46 PM »
Can you verify that the codes on the tanks are CF and IA?
I will keep looking for VL code, and let you know if I find it.
Re: Rad Tag Decode
« Reply #7 on: May 25, 2016, 03:41:37 AM »
The numbers are there. They are on every tag.
Re: Rad Tag Decode
« Reply #8 on: May 25, 2016, 12:10:16 PM »
Yes, with age and the effects of rust and or heavy paint, these numbers are very hard to see without some cleaning (solvent, stripper, pocket knife or sand paper) off that area. You could lie the radiator on a flat level surface and put 2 or 3 drops of white vinegar on that area and let sit for a day or 2. I use a dropper as you want a drop with bubble appearance more than just smearing or wiping on the vinegar  Try to use care in cleaning as the tag, sometimes, is worth more than the radiator!
LVN 67
Re: Rad Tag Decode
« Reply #9 on: May 25, 2016, 05:38:47 PM »
Got the rad back from the shop this morning. The letters on the side of the tank are C and F. The number at the bottom of the tag is 30147198
Re: Rad Tag Decode
« Reply #10 on: May 25, 2016, 06:28:45 PM »
The tanks are common to several radiators.  Is there an oil cooler on one of the tanks for transmission hookup?
Check the number again, you have one extra number in the series.
If it is 3014719 that is for a full size car.
LVN 67
Re: Rad Tag Decode
« Reply #11 on: May 25, 2016, 07:05:53 PM »
There is a space after the first seven numbers and the 8.
Re: Rad Tag Decode
« Reply #12 on: May 25, 2016, 08:09:38 PM »
OK, that is the part number and decodes to what I posted.  Does it have the Camaro radiator mounting brackets on the sides?  Someone may have modified it to work in that car.
LVN 67
Re: Rad Tag Decode
« Reply #13 on: May 25, 2016, 09:44:37 PM »
Here is a picture. Hope it is re sized correctly.
Re: Rad Tag Decode
« Reply #14 on: May 26, 2016, 04:57:43 AM »
It's listed for a 68-69 Chevy II / Nova. Auto with AC.
