Author Topic: 69 camaro front shoulder anchor point  (Read 9046 times)
69ZX77MP
« on: April 29, 2016, 11:24:05 PM »
HI I'm installing front shoulder belts my car never had them. Does anyone have interior pictures of where they anchor in the rear or measurements any help appericated.
1969 Z28 X77 Lemans Blue 03D
Rufcar
Re: 69 camaro front shoulder anchor point
« Reply #1 on: April 30, 2016, 01:37:49 PM »
When I did mine I unbolted the top roof belt and screwed in the new belt to the existing top anchor and lower anchor and that was it. I left the belt clips in until I installed a new headliner then I removed those clips.
« Reply #2 on: April 30, 2016, 03:36:14 PM »
I'm confused. Every 69 coupe had front shoulder belts - federally mandated. http://www.camaros.org/seatbelt.shtml#config
HawkX66
« Reply #3 on: April 30, 2016, 07:48:19 PM »
I'm sure if yours didn't have them, someone replaced your headliner at some point and didn't re-install them. Here's the pics from mine that show where the bolts go including the clips and coat hook:
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Rufcar
« Reply #4 on: April 30, 2016, 09:49:07 PM »
Kurt I believe we are both talking about the combined system all cars have today. Pull the end and both top and lap come together not separate.
HawkX66
« Reply #5 on: April 30, 2016, 10:34:06 PM »
If that's the case, he should be clearer with his question so we can help. Kurt and I are thinking he's talking about factory shoulder belts.
Dave
Semper Fi!
69ZX77MP
« Reply #6 on: May 01, 2016, 12:10:27 AM »
Your right Dave my headliner was replaced by previous owner he removed a lot of the interior and never replaced the front shoulder belts your pictures are very helpful now I know what to look for and feel around. Thanks to everone that responded. Sorry about the way I worded my question
HawkX66
« Reply #7 on: May 01, 2016, 12:44:48 AM »
Glad to help. It would have only been worded bad if you had meant after market belts. You're good...
Dave
Semper Fi!
69ZX77MP
« Reply #8 on: May 01, 2016, 05:22:47 PM »
Hi DAVE I found anchor bolt location still feeling for clips location do you have measurements from the coat hook to the first clip Thanks
HawkX66
« Reply #9 on: May 01, 2016, 06:04:28 PM »
Not handy, but I'll try to remember to grab it later.
Dave
Semper Fi!
69ZX77MP
« Reply #10 on: May 01, 2016, 11:13:47 PM »
thanks Dave I found them feeling around your pictures did the trick thanks belts installed
HawkX66
« Reply #11 on: May 02, 2016, 02:24:35 AM »
Glad to hear it. For anyone that comes across this, from the shoulder harness mount hole closest to the front, 4", 17" & 25" are where the holes are.
Dave
Semper Fi!
LB69#67
« Reply #12 on: May 11, 2019, 07:11:36 PM »
Dave, would it be possible to get the pictures?  I am trying to figure out where the shoulder strap mounting bolt holes are and the ones for the piece that holds the excess belt when not in use.  It is a 69 coupe.
LB69#67
« Reply #13 on: May 11, 2019, 07:24:23 PM »
Sorry, just saw the pictures.  Came in halfway into the topic.  Just need a measurement to find the shoulder belt holes.
