Author Topic: Proper engine decals location  (Read 37333 times)
lemarin
« on: April 25, 2016, 03:11:08 PM »
I just my complete engine/engine bay rebuilt and I'm now ready to install the decals, back to original state.
I do have few questions, maybe some pictures would be appreciated.
I bought a complete kit for my engine (LM-1 350/255) from heartbeat, and I'm wondering if it's the best kit ? Maybe there's few other decals I should buy separately elsewhere?
Now I'm wondering about the locations for 3 specific decals:
1-The brake booster tag: where should it be installed, exactly ? Any pictures ?
2-The pollution/exhaust emissions decals: on most of the car I see, they were directly located on the radiator top bar (or rack, not sure about the proper name of it). On my car, there's few plastic clip from under, so there's not enough room to stick the two decal. Anyway those two decals are too high to be stuck on this support. Maybe there's a better place to order those decal and they have the right size ? For now I stick them directly on the fan shroud, is ut correct ?
Jeep Grand Cherokee SRT 2017 brillant black
BMW M3 ZCP 2017 Yas Marina Blue
Chevrolet Camaro RS 1969 Daytona yellow
Tesla 3D 2018 AWD (ordered)
Re: Proper engine decals location
« Reply #1 on: April 25, 2016, 03:36:09 PM »
The original emissions/tuneup sticker on my car is located on top of the radiator support bar, just to the right (drivers side) of center.  It is NOT correct on the fan shroud.
HawkX66
« Reply #2 on: April 25, 2016, 04:42:58 PM »
Like Gary said, proper placement of the emissions decal is on the radiator support like this:
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
lemarin
« Reply #3 on: April 25, 2016, 05:52:35 PM »
Ok, that's what I taugh, but look at the pictures I took of my radiator bracket, compare to the size of both decals, and they can't fit in there !
Mark
« Reply #4 on: April 25, 2016, 06:13:40 PM »
It is correct to have the labels on the fan shroud if you have Air Conditioning, as the hood seal gets in the way of the labels in their normal location.  The cores support above is drilled for the A/C seal retainers.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
stovebolt
  • 1968 L6 Sport Coupe
« Reply #5 on: April 25, 2016, 06:27:47 PM »
These pics are of my unrestored original '68 coupe. The emissions decal is 1 1/4" wide.
lemarin
« Reply #6 on: April 25, 2016, 06:45:33 PM »
In fact, I believe the holes are made to secure the vacuum hose for the right headlamp cover. This hose is routed underneath the radiator support, using some plastic retainers.
Also I'm sure the replica decals are slightly bigger than the original ones....
Where did you bought yours ?
JKZ27
« Reply #7 on: April 25, 2016, 06:54:39 PM »
My original L48 with A/C decal is on the shroud. There is a rubber seal that should be on top of the core support and a foam seal between the radiator and the core support if it has A/C.
John
68 RS Ash/Ivy Gold 327EFI M20
lemarin
« Reply #8 on: April 26, 2016, 02:29:41 AM »
In addition of the Z22 kit, I do have also the A/C from the factory installed on mine....
What about the other decals ? Anybody has picture of their setup to show. It's hard to see pictures about that and originality through the web....
« Reply #9 on: April 27, 2016, 02:50:31 AM »
1. You are missing the AC seal that goes on top of the core support.
2. No first gen ever used that thermostat decal.
3. Tune-up decal is fine on the shroud since you have AC.
X33RS
« Reply #10 on: April 27, 2016, 03:31:17 AM »
Are you sure about #2 Kurt?
My Z being original in that area definitely had 2 decals on the core support.  It had the engine decal on the driver side as you would normally see.  On the passenger side mine has what I assume would have been some sort of coolant decal since it was close to the radiator fill.  However it was too deteriorated to make out what it might have been.
Is there another known decal on that side for early Norwood Z's?
lemarin
« Reply #11 on: April 27, 2016, 11:36:32 AM »
Kurt, do you have a picture of this AC seal ? I've seen pictures of many Camaro with AC equipped, but never notice this seal....
Does this seal available from repro ?
lemarin
« Reply #12 on: April 27, 2016, 11:41:51 AM »
Kurt, I've found a repro seal on heartbeat finally, but would appreciated to see a picture of it, once installed.
Also about the tire pressure driver door decal, if my car was originally equipped with F70-14 Redline tire, which one should I buy ?
This one ?
http://images.nitrosell.com/product_images/2/437/large-rps-1173.jpg
jl8dale
« Reply #13 on: April 27, 2016, 01:47:41 PM »
Here's a pic from a survivor 1969 Pace Car with AC that I used to own.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
lemarin
« Reply #14 on: April 27, 2016, 04:11:56 PM »
Great, thanks for the picture Dale. Can you tell me if the sticker on the shroud is an original one ? If yes, which one is it ?
