Author Topic: Subframe Removal  (Read 16117 times)
dtep
Subframe Removal
« on: April 20, 2016, 01:58:58 AM »
I'm working to make a '68 RS driveable for my wife and as I dug deeper into the car, I found that the #2 body mount points in the subframe are mostly rotted out under the bushings.  The engine, trans  and radiator are out and I disconnected the steering at the rag joint so the steering box and power steering pump stays with the subframe.  I have not removed the doghouse from the car.  The plan is to put 2x4's between the rockers and subframe and use my lift to raise the body off the subframe.  The question that I have is how much do I need to support the doghouse when it is off the subframe?  I'd hate to kink the tops of the fenders, but on the other hand, I'd also rather not spend a lot of time building a support structure that isn't really necessary.
JKZ27
Re: Subframe Removal
« Reply #1 on: April 20, 2016, 10:47:28 AM »
I dropped the subframe assembly including the engine and trans without removing any sheet metal from my 68. I left the wheels and tires on and just used some jack stands on the back rails. I didn't need any supports on the fenders although, I think I did remove the hood. I'm not sure what the "doghouse" is.
John
68 RS Ash/Ivy Gold 327EFI M20
HawkX66
« Reply #2 on: April 20, 2016, 12:09:50 PM »
You don't need to support the front sheet metal if it's all bolted on well. When you go to fix the mounts, IMO, don't use the "kits". Cut a square out, weld in a flat piece of new steel and bore a new 1 1/2" hole. Here's what mine looked like when I did it. Relatively easy.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #3 on: April 20, 2016, 12:42:04 PM »
FYI.. 'doghouse' is an older term for the complete front sheet metal assembly (fenders, hood, grill, etc - as an assembly)..
dtep
« Reply #4 on: April 20, 2016, 01:15:22 PM »
[/quote]
"an older term"...Youch!!  But I guess I resemble that remark.     ;) :-\
Thanks to all for the input.
« Reply #5 on: April 20, 2016, 02:02:31 PM »
:)   It just means we have *experience* going back many years..  :)
« Reply #6 on: April 20, 2016, 03:23:35 PM »
I think "doghouse" may also be a midwest slang term for the front sheetmetal.
Maybe you just didn't grow up in red neck area to hear this term.... ;D
Others here on the west coast can chime in, but I learned this term after spending a lot of time around different car guys from different parts of the country. I figure it is rooted in the idea that it either visually resembles a dog house when removed( the fire wall side would be the opening when siting on the ground?) or some guys actually used them for there dog as a dog house back in the day?
Different regions of the country seem like they have different slang for the same stuff, even car related terms and ideas. :)
« Reply #7 on: April 21, 2016, 02:03:47 AM »
Back in the 50's and 60's, you could search junkyards all over the country for 'doghouse' and everyone everywhere knew you were speaking of the complete front sheet metal as a unit... (used to repair many cars which were damaged in the front due to collision).. :)   GO to your local junkyard (if you still have one) and see if they know what you mean by 'doghouse'.. :)
« Reply #8 on: April 21, 2016, 02:49:13 AM »
Nice! How did you know where to drill the hole?
dtep
« Reply #9 on: April 21, 2016, 03:09:31 AM »
I'm all about expanding people's vocabulary, so now that we have "doghouse" down, let's move on to "left three quarters doghouse" and "right three quarters doghouse"...    ???    ;D
« Reply #10 on: April 21, 2016, 03:12:39 AM »
That's everything but the Left (or right) fender...  :)
« Reply #11 on: April 21, 2016, 03:21:09 AM »
If it were me I could take the piece I cut out and put it on the under side lined up with the cuts and make a circle in pencil and then go over it with a scribe. Do your pilot hole from under, and then the rest from on top. ( I am sure there is more than one way to do it)
« Reply #12 on: April 21, 2016, 08:43:22 AM »
X2 Nice!
HawkX66
« Reply #13 on: April 21, 2016, 11:54:36 AM »
Thanks Kurt. That's one of my repairs I was pretty proud of lol. I had a spare subframe with a good mount that I was able to make a steel template from. Now I'll always have the template too if you know anyone local that needs to use it.
X2 Nice!
Thank you sir...
Dave
Semper Fi!
JKZ27
« Reply #14 on: April 21, 2016, 01:18:06 PM »
Thanks for the "doghouse" definition fellas.  :)
Here is a pic from my subframe removal.
John
