Author Topic: Trunk Spatter Paint Color for 1st Gens.  (Read 68440 times)
Pex68
Re: Trunk Spatter Paint Color for 1st Gens.
« Reply #30 on: June 02, 2009, 02:08:25 PM »
Anyone got some some pic's of a original 68 trunk???  Seems almost every pic I see is of a 69 and the ones that aren't don't have the filler neck cover in the shot >:(  Just need to know if it's splattered too and if so is the mounting screw splattered and is the latch support splattered behind where the cover installs?
Thanks Guys!
Chris P
1968 Z28
« Reply #31 on: June 02, 2009, 02:45:05 PM »
Hey Chris,
  I have a 68 Z28 with an original trunk.  I will try to get some photos today.
Jerry G.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
cancam69
« Reply #32 on: June 02, 2009, 02:51:18 PM »
Two vendors are making the correct truck spatter paint for first gen Camaros.  Larry Christensen at Camaros Plus in Arvada, CO and Brian Henderson at Supercar Workshop in LaTrobe, PA.  Both are the accepted standard in concours judging and pretty damn close to the original.  A professional pressure gun is needed to apply this paint.  If you are hoping to find the right stuff in a rattle can, forget it.
Jerry
Jerry, would you know if anyone is distributing this product up here in Canada? I went for a longshot today and tried my local GM Dealership for the splatter paint that was previously posted here....not even on their Radar anymore....thanks in advance for your help.
Pex68
« Reply #33 on: June 02, 2009, 04:06:02 PM »
Hey Chris,
Jerry G.
THANKS JERRY!!!!!!!!!!!!!
Chris P
vtfb68
« Reply #34 on: June 03, 2009, 12:39:29 AM »
Pex,
Check your e-mail for trunk pictures. Hope it helps.
  VTFB68
68 08E LA RS Y2 749 L30 M35
Pex68
« Reply #35 on: June 03, 2009, 12:15:26 PM »
Pex,
  VTFB68
VTFB68, didn't get the email, could you send again?
Jerry G., anything you can send or post too would be great!
Getting ready to re-spray trunk...
Could you guys also let me know date & plant of the cars?
Thanks again guys!
Chris P
CVKUEBER
« Reply #36 on: June 03, 2009, 06:39:44 PM »
The GM paint is still obtainable. 1051499 for black/aqua   1051498 for gray/white
1968 Z28
« Reply #37 on: June 04, 2009, 01:24:24 PM »
Chris.....I have a 07C 1968 Norwood car.  Haven't had a chance to get to the garage with the camara but I did go by and look.  It has a coating of black and white speckle and the gas filler cover is speckled but the screw looks like a regular phosphate one and it appears to be speckled behind the filler tube as well.
Hope that helps...
Jerry G.
Jerry G.
big iron
« Reply #38 on: June 04, 2009, 02:14:33 PM »
So you are saying that the trunk and cover where spatter painted at the same time  then the cover was installed later  in the production process. Does anyone know where the cover was actually spatter painted ( in the trunk on a wire or off line)?
What color is the back of the cover? Some % of black or body primer?
Bob
Chris.....I have a 07C 1968 Norwood car.  Haven't had a chance to get to the garage with the camaro but I did go by and look.  It has a coating of black and white speckle and the gas filler cover is speckled but the screw looks like a regular phosphate one and it appears to be speckled behind the filler tube as well.
Hope that helps...
Jerry G.
ssours
« Reply #39 on: June 04, 2009, 03:24:32 PM »
Am I correct in assuming there was never carpet or liner installed by the factory?
big iron
« Reply #40 on: June 04, 2009, 04:02:39 PM »
Deluxe interior received trunk mat.
Bob
rat pack
« Reply #41 on: June 04, 2009, 07:28:05 PM »
All of the ones I have observed had spatter paint on them, so Chevrolet must have been painting them. I will see if I can dig up some pictures of the original ones I have around here that are not restored...................RatPack.......................
68Tom
  • Guest
« Reply #42 on: June 04, 2009, 08:22:58 PM »
Question is, does it look the same?  I know GM sells it in the spray can, but I'm fairly certain it doesn't look the same.  Perhaps I'm off on this.  Anyone have experience with it?
Pex68
« Reply #43 on: June 04, 2009, 11:32:49 PM »
It's close, and dries rock hard, but being that it is being sprayed from a can and not a gun the pattern is way off so it looks totally different.
Really appreciate all the help from from everyone so far!!!
Chris P
