Author Topic: Hurst Shifter date codes  (Read 165445 times)
Re: Hurst Shifter date codes
« Reply #105 on: November 10, 2019, 02:05:36 PM »
Yes that it what I have seen too Joe. Flat washer and cotter pin on those with rubber - most common with GTO shifters.
« Reply #106 on: November 11, 2019, 12:37:17 AM »
thanks Joe I will review the AIM
« Reply #107 on: November 12, 2019, 03:57:05 PM »
Car     Plant    Shifter Date
09D     LOS     88D3
10B     LOS     88D4
10B     NOR     68B2
12B     NOR     68B2
12D     NOR     1280D31D
02A     NOR     19D51J
02C     LOS     19D52M
03B     NOR     19D52P
04A     LOS     29D21C
04B     LOS     19D53D
05A     NOR     19D51Q
05A     NOR     19D35E
06A     NOR     19D42M
06A     NOR     19D43D
07A     NOR     69O711F
09C     NOR     89O731C
Updated:  Nov 12 2019
rszmjt
« Reply #108 on: November 24, 2019, 08:09:41 PM »
My 06A Z28 shifter is 19D51C, Owned the car since 1974, and the rod clips are flat type clips, not hurst spring type or cotter pins.
cruizin69
« Reply #109 on: December 16, 2019, 07:41:12 PM »
Build date:  03B
Shifter code:  19D52P
/quote]
Build date: 02A
Shifter code: 19D51J
cruizin69
« Reply #110 on: December 16, 2019, 07:50:52 PM »
The date Code on my shifter is 19D51J from a 02A Z/28
My 02A Z/28 is Norwood car shifter 19D51J
COPOZ/28
« Reply #111 on: March 09, 2020, 03:26:24 PM »
Here's the info on my '69 Z and shifter.  Am the 2nd owner since Nov of '79.  Knew the 1st owner very well and helped him order the car, including the 4.88 axle ratio via the COPO system.  The car's block/fitted pistons were replaced under warranty in the spring of '70 due to a loose wrist pin retainer scoring a bore.  After getting the car back from the dealer, the 1st owner removed the engine/trans and prepped the car for drag racing (decked the "CE" block, honed extra piston to wall clearance, changed the 4.88 gear to 5.38, etc., etc.)  I helped re-assemble the engine and get the car back together.  The car ran 113 MPH at Van Wert Dragstrip in NW Ohio but didn't ET well -- my friend weighed 300 lbs and did not have the assistance of Bill Jenkins building/tuning the engine and chassis, like his hero Dave Strickler had. The car was not licensed or driven after 1972 and sat until I circled back to buy the car in '79.  All of this is not proof of the shifter being original to the car, but with the M22 and rear axle being original to it, one does wonder.  Shifter attachment bolt heads can be seen in the attached photo -- do they appear as the correct fasteners?  I'm asking as both the engine and trans had been taken out of the car at least twice (once by dealer in early '70, once by 1st owner in mid-summer of '70) before my purchase in '79.  I've done it at least twice since then.
Many thanks to everyone who helped make, and continue to make, this forum the remarkable reference site it is.  I "found" it only just recently and promptly joined, and have already benefited greatly from the knowledge contained throughout the site.  My interest in learning more about my car runs in spurts, having owned it for so many years.  Right now, I'm definitely in the middle of another "spurt!"  Thanks again.
05E NOR Build
19D51Q Shifter code
3138 Stamping appears on front of shifter body
Shift levers have the molded in rubber style inserts
Shift rods attached via curly round wire (aka Hurst?) spring clips without any washers
P9E14C Stamped trans code (VIN stamp matches car VIN)
3950318 Trans metal ID tag
BX 0429 G2 E Axle code stamping on tube
Chuck B.
Ice cream run in our '69 Z/28 on Woodward Ave. in Royal Oak.
Daytona Yellow, NOR 05E, X33, M22, 4.88/COPO 9511CB.
Jonesy
  • 1969 Camaro z28
« Reply #112 on: November 23, 2021, 10:55:02 PM »
My 1969 Van Nuys Z28 02A has its original shifter and the stamping on the body is 19D33D
1969 Z28 Azure Turquoise
