Author Topic: CRG Shifter Report  (Read 23375 times)
HustleRussell
Re: CRG Shifter Report
« Reply #15 on: April 03, 2016, 01:05:19 AM »
Awesome information Kurt & Martin. This is the most awesome website on the net IMO. However the shifter handle in my 69 MC1 Camaro has the word "MUCICIE" stamped in it, which disagrees with yall's research. So I'll assume either my shifter handle is not original or the MC1 transmission is so rare it might have been over looked. I'm looking forward to JKZ27 aka John chiming in as he is the only other member on this website that I know of having a MC1 transmission.
Russ
68 RS
69 SS
« Reply #16 on: April 03, 2016, 01:34:01 AM »
What is the build month and week of your car?
HawkX66
« Reply #17 on: April 03, 2016, 01:43:01 AM »
Kurt, I noticed in the shifter ball section you didn't have a 69 ball listed. Is the chrome ball listed as a 68 actually a 69?
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
JKZ27
« Reply #18 on: April 03, 2016, 01:44:34 AM »
Thanks for the great report fellas!
My MC1 handle does have MUNCIE stamped on it. I would guess Kurt is aware of the MC1 Muncie handle but maybe overlooked it during the write up because most of the 69 3 speeds were Saginaw which received a blank handle. Also, I wouldn't say the MC1 was rare it was just unpopular. And, as Kurt has said, most have been converted to a 4 speed by now which makes them rare today. The only real telltale might be the square shifter hole.
John
68 RS Ash/Ivy Gold 327EFI M20
HustleRussell
« Reply #19 on: April 03, 2016, 01:55:46 AM »
My MC1 Camaro was build last week in February NOR.
Russ
68 RS
69 SS
HustleRussell
« Reply #20 on: April 03, 2016, 02:02:46 AM »
transmission & shifter.
Russ
68 RS
69 SS
JKZ27
« Reply #21 on: April 03, 2016, 02:11:04 AM »
Dave, I see the 69 knobs and descriptions are listed but there are just no pictures.
John
« Reply #22 on: April 03, 2016, 03:06:03 AM »
Thanks Russ. We will take a look.
The MC1 was a Muncie 3 speed, so I guess it is possible it used a Muncie shifter handle.
« Reply #23 on: April 03, 2016, 03:23:37 AM »
When did the Firebird start using the same Hurst shifters as the 69 Camaro? Is the answer: since the 1st Bird (67)?
JoeC
« Reply #24 on: April 03, 2016, 09:02:03 AM »
Firebird used the Muncie shifter in 1967 and the Hurst in 1968
Pontiac began a long history with Hurst beginning with GTO and LeMans  using  a round stick Hurst shifter in 1964
« Reply #25 on: April 03, 2016, 12:19:41 PM »
Went thru the report and as many have stated well done and an excellent report. Jerry and Joe had helped (thanks again Jerry and Joe) with my Muncie set up as the stabilizer bar was missing and I ended up with all three and found it difficult to research. This CRG report is going to assist many when both identifying correct parts and restoration.
Thanks Kurt, Martin and all involved.....
JoeC
« Reply #26 on: April 04, 2016, 12:43:35 AM »
On the Muncie shifter chrome sticks where some Muncie trans cars were found without the MUNCIE stamp. This question has been around for many years and is hard to say if the car came from the factory that way or not.
One thing I found interesting was back in the 1980s I bought a NOS Muncie shifter from a swap meet. The seller was a Chevy dealer mechanic and was selling off NOS items to clear out the dealer stock room. He told me he remembered replacing many Muncie shifters due to customer complaints of poor shifting. There was a part number where you can order a replacement shifter. It was the chrome stick and shifter body but no rods or mount plate or other parts,
I have had a few of these NOS units over the years, so that tells me the dealers did use these to some degree.
I had some with the Muncie stamp and some without.
I still see these come up for sale occasionally. This one was on ebay recently.
last pic, Some factory installed shifters have  a yellow paint inspection mark on them but I don't see it on the replacement units.
jdv69z
  • 69 RS Z/28 52E
« Reply #27 on: April 05, 2016, 12:14:28 AM »
So attached is a pic of the Hurst shifter from my 69 Z, build 10B, Oct 68. Shifter is dated  6  8B2. The 6 is hard to see. That's Jun 1968, correct? According to the article, my shifter is date coded for a Firebird? Did I read that right?
Jimmy V.
« Reply #28 on: April 05, 2016, 08:09:36 AM »
Your shifter date is June of 68. Probably original for your car.
Shifters are date coded, not necessarily for application. The one in the article used is one I have and I knew where it was from. We may swap that particular pic out for a different one.
« Reply #29 on: April 05, 2016, 09:10:10 PM »
X2 on 68B2 off my 12B. I am/was beginning to be concerned that this shifter was not the OE. Not so sure now. Seems unlikely 2 have the same dates, but 6 months?. Anyone else?
