Author Topic: Electrical fuses  (Read 9906 times)
sam
Electrical fuses
« on: December 20, 2006, 12:34:10 AM »
Did the Norwood plant use different color fuses in their fuse blocks, for different amperage? Example red tip fuses would be 10A and white tip would be 20A? Any othere colors for the 25A and the 4A?  Thanks,  sam
hotrod68
  • almost finished
Re: Electrical fuses
« Reply #1 on: December 20, 2006, 05:39:11 AM »
I believe they used the Industry standard fuses, Sam, just like light bulbs and headlights. They came in bulk from the vendor like everything else. I've never heard of special fuses for different assembly plants. John Z would know.
« Reply #2 on: December 20, 2006, 07:41:07 PM »
Fuses were color-coded starting in 1967, using a colored strip INSIDE the glass tube (reproductions have a colored band around the OUTSIDE of the glass), and were coded as follows:
4-amp: pink
10-amp: red
20-amp: no color
25-amp: white
30-amp: green
Fuses came already in the fuse block from Packard Electric, except for options that had their own fuse - those were installed at the car assembly plants.
My 02D '69Z still has five of its original color-coded fuses.  :)
sam
« Reply #3 on: December 21, 2006, 02:44:09 AM »
Thanks John!  Sam
Pacecarjeff
    • pacecarjeff.com
« Reply #4 on: December 22, 2006, 12:37:23 AM »
I thought NCRS had determmined that the colors started iin 68.
The colors were used right up till they went to the new fuse design 1980 ish
Oops John - never mind you are right, just checked my 67 judging manual - they are now noted in the newest revision.
You certainly keep up on this stuff  ;D
« Last Edit: December 22, 2006, 03:40:26 AM by Pacecarjeff »
« Reply #5 on: December 22, 2006, 08:47:37 PM »
Look on the inside front cover where the members of the Manual Revision Team are listed. :)
Pacecarjeff
    • pacecarjeff.com
« Reply #6 on: December 22, 2006, 09:00:45 PM »
There you are. :)
VERY COOL JOHN!!!
