Author Topic: 69 fuel tank sending unit  (Read 2551 times)
john302
« on: February 28, 2016, 10:01:27 PM »
Does anyone have any pics or info on the foam/rubber sleeve on the lines of the fuel tank sending unit?The sender is a dual line/return line sender.I know what the sleeve is like for the single line sender.I need to came up with something to make one.thanks John  p.s. Its the protective sleeve to prevent the lines from rubbing on the fuel tank strap
