Author Topic: 68 L78 Rallye Green  (Read 138623 times)
Re: 68 L78 Rallye Green
« Reply #60 on: March 03, 2016, 01:40:36 AM »
Original smog pump, pump brackets & manifolds.  Everything was derusted and protected with Rust Veto.
Exhaust manifolds along with the portion of the head pipes that was cut off when headers were installed.
Passenger side.
« Reply #61 on: March 03, 2016, 01:41:50 AM »
Passenger side casting number and casting date. (photos taken before derusting)
« Reply #62 on: March 03, 2016, 01:44:24 AM »
Drivers side
« Reply #63 on: March 03, 2016, 01:45:07 AM »
Drivers side casting number and casting date. (Photos taken before derusting)
« Reply #64 on: March 03, 2016, 01:48:21 AM »
Pump, brackets & hoses.
« Reply #65 on: March 03, 2016, 01:51:35 AM »
Main bracket
« Reply #66 on: March 03, 2016, 01:52:14 AM »
Adjusting bracket
« Reply #67 on: March 03, 2016, 01:53:53 AM »
Main bracket bolts and adjusting bracket bolt.
« Reply #68 on: March 03, 2016, 01:55:26 AM »
Diverter valve bolts, diverter valve housing that bolts to pump bolts.
« Reply #69 on: March 03, 2016, 01:56:31 AM »
Pulley and bolts.
« Reply #70 on: March 03, 2016, 01:57:29 AM »
Hose markings and pump stamping.
« Reply #71 on: March 04, 2016, 06:40:04 PM »
Pretty sure the hose is dated  11027   11th month 2nd day 1967
« Reply #72 on: March 04, 2016, 08:08:29 PM »
There are clamps dated 4/67 & 1/68 so I wouldnt be surprised by that date.
« Reply #73 on: March 04, 2016, 11:26:40 PM »
The rubber GAS line on the 12C X66 conv from a couple of years ago had 10308 on it.  Tenth month 30th day 1968 is what I figured.
« Reply #74 on: March 05, 2016, 12:05:07 PM »
BTW I'm sure you noticed but I used your trick on the hoses.. ;)
