Author Topic: 12 Bolt Rear End Identify  (Read 15522 times)
Re: 12 Bolt Rear End Identify
« Reply #15 on: January 30, 2016, 04:46:03 PM »
Not sure about the window sticker.
« Reply #16 on: January 30, 2016, 04:48:17 PM »
Can you tell us the casting date on the center section of the rear axle?
uscgreel
« Reply #17 on: January 30, 2016, 06:08:45 PM »
uscgreel
             Have you verified what gear is in your rear end? And also is it a posi? Could the stamp be wrong??
It is a posi, drives like a 4.10, and is 12 bolt. But as far as opening it up, no I haven't done that....But as I am typing this, there is probably a way to count the revolutions. Might look into that...
« Reply #18 on: January 30, 2016, 07:45:49 PM »
Unfortunately, that window sticker is not an original. :(
« Reply #19 on: January 31, 2016, 07:32:54 AM »
I also agree it is not an original... :(
FWIW The ECL codes are wrong.
uscgreel
« Reply #20 on: January 31, 2016, 05:51:46 PM »
Ok, thanks.
« Reply #21 on: January 31, 2016, 06:08:42 PM »
VIN: 124379N660601
« Reply #22 on: January 31, 2016, 06:22:55 PM »
Well the good news is , maybe your rear end is original then?
« Reply #23 on: January 31, 2016, 11:00:15 PM »
I think it could be original. If it has the right casting year.
fsc66
« Reply #24 on: February 21, 2016, 04:46:03 PM »
This window sticker is not real.
HawkX66
« Reply #25 on: February 22, 2016, 01:05:30 PM »
If you jack up the rear end and spin the wheels, you can figure out what rear end gears are in your housing. If the driveshaft spins ~4.1 times per revolution of the tires, you have 4.10 gears. 3 1/2 times, 3.55s. No need to crack open the diff cover.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
