Author Topic: DZ Block ?  (Read 12862 times)
Camaro Billy
    • 1969 RS/SS
DZ Block ?
« on: December 11, 2006, 11:08:36 PM »
I was looking at a small block today w/ casting #3956618, casting date C 139.
It has been decked so no numbers on the pad.It has the 3941178 302 crank, I could tell by the crankshaft flange.The heads and intake are later pieces.
I found the VIN on the rough casting near the oil filter flange, but it was very hard to read.
The best I could tell was -
 19N627_14
Couldn't read the 3rd to last number but for sure starts w/ 627.
Is that enough info to see if the car might be in the data base?
What else should I look at to try and confirm it's a DZ ?
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
Re: DZ Block ?
« Reply #1 on: December 12, 2006, 12:34:18 AM »
There was no block casting specific to the 302 engine.
The castings used by Chevrolet to build them were also used for 300 & 350 hp 350 engines. The block in question did come from a Camaro but with the code gone there is no way to tell if it was a 302. Since it has been messed with the crank may not be original.
Re: DZ Block ?
« Reply #2 on: December 12, 2006, 01:31:25 AM »
Billy,
Is it at least a 4 bolt block? If so, then it's either 1 of 3 things:
1. 350/300 (SS)
2. 302/290 (Z28)
3. Redrilled for 4 bolt mains
rich69rs
  • LF7/M35/Z22/Z87
Re: DZ Block ?
« Reply #3 on: December 12, 2006, 01:33:58 AM »
Seems like I recall a discussion in the past dealing with acid etching to try and bring out the numbers after the block (and pad) had been decked.  I did a quick word seach and couldn't find anything.  It may be worth a little research.
Richard Thomas
1969 RS
Steve68
Re: DZ Block ?
« Reply #4 on: December 12, 2006, 01:45:54 AM »
Here is a link to etching.  http://www.camaros.org/public/acidetch.txt
Camaro Billy
    • 1969 RS/SS
Re: DZ Block ?
« Reply #5 on: December 12, 2006, 02:09:15 AM »
 Sorry I should of said it was a 4 bolt.
The owner had asked if I knew how to etch it. I think I can see a slight impression on the pad as it is.Those instructions are great.If we give it a try, I'll post back.
Thanks for the info.
Billy
Re: DZ Block ?
« Reply #6 on: December 12, 2006, 07:07:57 PM »
A few VIN's in the db close to matching, but none do.
Camaro Billy
    • 1969 RS/SS
Re: DZ Block ?
« Reply #7 on: December 12, 2006, 11:09:37 PM »
Kurt,
I took some photos and then blew them up.Still a little hard to tell, but I beleive it is-
19N627445
Here is a shot
Billy
Camaro Billy
    • 1969 RS/SS
Re: DZ Block ?
« Reply #8 on: December 14, 2006, 01:00:23 PM »
Here is a shot of the crank.Can anyone confirm that it is from a 302 DZ block ?
Billy
Re: DZ Block ?
« Reply #9 on: December 14, 2006, 04:38:15 PM »
Looks like an 1178 crank flange to me.  :)
Re: DZ Block ?
« Reply #10 on: December 16, 2006, 03:46:09 AM »
That VIN isn't in the db. One exactly 20 off from it is there, but close only counts in.....  :)
Camaro Billy
    • 1969 RS/SS
Re: DZ Block ?
« Reply #11 on: December 16, 2006, 03:15:53 PM »
Thanks again Kurt
Billy
Jerry@CHP
Re: DZ Block ?
« Reply #12 on: December 17, 2006, 02:25:53 AM »
Billy,
Can you e-mail a photo of the vin stamping when you have a chance.
Jerry
z28camaroman@juno.com
