I went this route with the stockish turbo muffler in hopes that my wife approves.
She is fine with the Pypes transverse systems I've used, they are actually rather quiet inside the car with no drone at all, so I suspect this Dynomax turbo muffler should be similar if not maybe a tad quieter.
If it passes the wife test I may pull the muffler and install the dynomax ultraflow for a little sound comparison. If I get in trouble I can always switch back.
I just didn't go with the Pypes on the Z this time around (even though it's a wife safe system) because I really feel the need to run factory reproduction tail pipes. Can't do that on the Pypes system. If you have ever seen the muffler design on that system it's rather unique. It's a transverse "race pro" with one side having the inlet coming in the top on one side and exiting the bottom on the other side. On the other side the inlet is on the bottom and the outlet comes out the top on the other side. Making the tailpipes specific for the application. This particular cross flow muffler has a straight through design (same pipe enters and exits the muffler case) hence the reason for the opposite enter and exit locations on the muffler.
Fitment has always been excellent, I like the stainless construction, the "X" pipe, and most important the sound level is great with no resonance inside the car.
