Author Topic: Engine Block Decode  (Read 4931 times)
Jek9016
Engine Block Decode
« on: January 10, 2016, 09:36:58 PM »
I have a later 350 installed in my 67.  Have not had any luck decoding the numbers, wonder if anyone can help.
Front passenger side under the head has 12K523985
On the rear of the block, where the bell housing attaches under the intake I see 9970010.
Anyone ever run across these numbers?
Re: Engine Block Decode
« Reply #1 on: January 10, 2016, 11:20:28 PM »
I answered your other post. Casting number is most likely 3970010 and engine most likely from a 1972 Chevelle.
Post what else is stamped on the front pad of the block in front of the passenger side cylinder head if you want to know more about what that 350 was originally.
Jek9016
« Reply #2 on: January 10, 2016, 11:57:24 PM »
The number on the front of the engine is 12K523985
I was trying to find out if its a 2 or 4 bolt main
I figured it was early 70s with the hei dist
« Reply #3 on: January 11, 2016, 12:28:09 AM »
No way to tell with just the numbers you provided.
Look on the pad again. There should be something similar to V0514CLT. It won't be exactly that - but similar. Post a pic if you can.
Only way to tell 2 bolt or 4 bolt main for sure it to drop the oil pan. In most cases it's not that important.
Gramps69Z
  • 69 X33 D80
« Reply #4 on: January 11, 2016, 01:09:54 AM »
Should be 3970010.
Captain John Wykoff
