Author Topic: 8N373772 - Z/28 Engine  (Read 4148 times)
« on: January 08, 2016, 03:45:23 AM »
Your 302cid/290hp Z/28 engine block is on eBay...
Engine pad is stamped: 18N373772  V1226MO
Block casting number: 3914678
Block casting date: L 19 7
Seller id: 427-king
Seller location: Morris, CT
http://www.ebay.com/itm/1968-Camaro-Z28-MO-Coded-302-Motor/231770915220?_trksid=p2047675.c100012.m1985&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131230161411%26meid%3D7cd5b3320140422e915d0a2af46b5576%26pid%3D100012%26rk%3D2%26rkt%3D10%26sd%3D121816694062
Re: 8N373772 - Z/28 Engine
« Reply #1 on: September 28, 2016, 04:34:41 AM »
9-27-16: "This listing was ended by the seller because the item is no longer available."
