Author Topic: 67 Turbo 400 ID TAG and Detailing  (Read 18477 times)
Re: 67 Turbo 400 ID TAG and Detailing
« Reply #15 on: January 08, 2016, 03:58:16 PM »
Well here is a 1968 L35 TH400 Tag (UNRESTORED)
Kelley W King
« Reply #16 on: January 08, 2016, 04:54:59 PM »
My 69 CX is yellow. Wonder why the color changes?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #17 on: January 08, 2016, 06:22:25 PM »
Cleaning that one is all that is needed...  :)
« Reply #18 on: January 08, 2016, 06:36:03 PM »
Here is my CX tag, it cleaned up and the yellow is brighter after a cleaning with WD40 (Light solvent).
BTW it is out of a Kansan build L78 A body Camas Washington Chev car.
Camarocards
« Reply #19 on: January 09, 2016, 03:27:40 AM »
Quote
Wonder why the color change?
Not sure why there is a color change. If you search e-bay for "transmission tag" ( http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=transmission+tag&rt=nc) you'll see that someone is selling unstamped surplus tags that are a yellow, black, and teal. The two letter designation (e.g. "CC", "CX", etc) has to do with the engine and transmission combination.
Bob
Bob
'68 SS L35 01D
big iron
« Reply #20 on: January 09, 2016, 07:37:03 PM »
Wait a minute, I getting confused now. What color are the '67 CC tags again?
They should be black and CA prefix tags are used on 67 Camaro BB's. CC prefix tags are used on BB Chevelles. CB was used on the big 427 Chevy's
Bob
« Reply #21 on: January 09, 2016, 09:14:13 PM »
 I had sent Kurt a pic of the tag back in Jan 2011. I'm trying to find that photo but no luck so far. I do remember it being yellow though.
The car presently is encased in plastic on the lift while the convertible is being restored. I tried to get a picture today but I can't reach under it enough. I need one of those "selfie" gizmos and use the iPod for extended reach.
 As soon as I get (or find) the photo I'll post it.
big iron
« Reply #22 on: January 11, 2016, 10:30:51 PM »
Does anyone know at what plant the Julian assembly date code on the transmission tag was stamped at? Most research indicates that it was at the Hydramatic plant but I believe it was at the engine dress line.
Looked at the CRG 67-69 Camaro Driveline Decoding but it does not tell where the stamping was done, but it indicates that is was done at the Hydramatic plant.
Bob
« Reply #23 on: January 11, 2016, 10:33:39 PM »
A transmission mfg plate SHOULD have been installed in the transmission plant where it was built; otherwise wouldn't make much sense to me...??
« Reply #24 on: January 13, 2016, 04:20:27 AM »
Mike,
Here you go. Black.
And all the data on the trans tag was stamped at the trans plant.
« Reply #25 on: January 13, 2016, 04:34:06 AM »
 Thank you, Kurt! Yep...that's indeed the picture I sent you. You saved me from unwrapping the car to get under it for a better view.
I don't know why I see a yellow in my mind. I stand corrected now  :D
big iron
« Reply #26 on: January 13, 2016, 09:56:31 PM »
Bob
Update..... Should be black with CC prefix tags on 67 Camaro BB's. CA's used on full size Chevrolets because of long output shaft.
Thank you KurtS and MikeS.
Bob
« Last Edit: January 14, 2016, 02:39:46 AM by KurtS »
