Author Topic: 1969 Camaro Convertible Firewall cowl project  (Read 18404 times)
69 Zee
« on: December 30, 2015, 03:12:08 AM »
Anyone in need of the entire cowl clip?  Best jump on it now before it's to late  ;D  But first run to your favorite bank and take out a second mortgage !  :o
One can only imagine what he'd want for his parts when he's ready to sell them...YIKES !!
http://cgi.ebay.com/ebaymotors/Chevrolet-Camaro-RS-SS-/252228350160?hash=item3ab9fb30d0:g:H80AAOSwJcZWgHKW&vxp=mtr
Darrell
BillOhio
    • photobucket
Re: 1969 Camaro Convertible Firewall cowl project
« Reply #1 on: December 30, 2015, 04:45:10 AM »
This looks familar. did we see this before or did I have a long day?
1968 RS 327 4 speed
« Reply #2 on: December 30, 2015, 04:48:19 AM »
38 bids so far? Hmmmm...makes me wonder if those are real bidders.
« Reply #3 on: December 30, 2015, 01:21:18 PM »
Tag looks fake, firewall looks to have only had standard brakes and not power..  Also if you look at the speedo hole & clip areas they have a different look similar to the area around the tag..  I would bet the tag doesnt line up with the vin..  I smell a rat and I dont mean a big block...
Boston14
« Reply #4 on: December 31, 2015, 03:41:30 PM »
I believe Darrell is correct.  Definitely something fraudulent going on.  Rockers are for coupe, NOT convertible.
boston14
1969 SS/RS 350 Convertible
« Reply #5 on: December 31, 2015, 04:56:56 PM »
 :o If it is a 713 interior as tag shows, then where is the assist strap above glove box (and its holes for such)??...along with woodgrain etc...and NO Camaro emblem above the g. box. ::)
69 Zee
« Reply #6 on: December 31, 2015, 06:14:00 PM »
Also if correct..713 (Black Houndstooth) was not an option on convertibles other than the Pace Car
http://www.camaros.org/numbers.shtml#InteriorColors
Darrell
« Reply #7 on: January 01, 2016, 03:54:37 AM »
I imagine to the buyer this cowl means nothing, as obviously the bidders are looking for the tag and VIN to cobble up a rebody. Question posed above is relevant - does the tag date correlate to the VIN bracket ? Since the seller conveniently covered both with Ford sheet metal patch tape, we won't be able to keep an eye on this one. Someone will trying to pass this one off in the future -
Maybe the buyer will attach the trim tag to the Dynacorn or recipient with sheet metal screws, or pop rivets. That's always amusing, no matter how many times I've seen it.
HustleRussell
« Reply #8 on: January 01, 2016, 04:40:57 PM »
Zooming in on trim tag. Date code is 09 A. VIN 9N679---. CRG general info, end of month reports, states the end of August 69 was VIN 9N678253. The numbers appear to be from same time period. If the Muncie speedo cable piercing is from factory, that would indicate factory SS with manual transmission. I think seller covered #'s to prevent CRG from exposing this project after it's completed and up for sale on e-bay.    http://www.camaros.org/geninfo.shtml
Russ
68 RS
69 SS
« Reply #9 on: January 01, 2016, 05:08:02 PM »
hmmph
HustleRussell
« Reply #10 on: January 01, 2016, 06:03:08 PM »
I stand corrected. Muncie hole could also indicate COPO or Z/28. But why fake an SS if it was factory COPO or Z/28?
Russ
68 RS
69 SS
HustleRussell
« Reply #11 on: January 02, 2016, 01:33:08 AM »
I still think of my self as newbie. I'm still learning. Just thought id say no doubt trim tag is fake. But if Muncie hole was cut from factory it is real SS,Z28 or COPO with manual trans right?
Russ
68 RS
69 SS
Spooky
« Reply #12 on: January 03, 2016, 12:20:32 AM »
If the muncie hole was there, wouldn't it have a hole for the speedo clip? I see just the dimple on where it would have been punched if needed......
Scott
« Reply #13 on: January 03, 2016, 01:44:21 AM »
Hey Spookster!! Welcome aboard! You know me. PM me.
 That would make  sense, the clip hole. But I would not use the fact that the lack of a piercing rules out what trans. a car came with, as there were some inconsistencies that have been noted on cars and it is possible a piercing got missed, I guess? That cowl has so many other  issues though, the piercing  just one of many.
HustleRussell
« Reply #14 on: January 03, 2016, 02:11:30 AM »
I think spooky is right on. More proof this is not as advertised.
Russ
68 RS
69 SS
