Author Topic: Drive shaft U-Joint clamps/brackets  (Read 3521 times)
camaroman1969
« on: December 29, 2015, 01:34:12 AM »
Hi guys.  Have a question.  Drive shaft U-Joint has two (2) brackets holding it on drive shaft.   Brackets have numbers 1 thru 4 stamped on top of the bracket.  Does anyone know why??  thanks!
Re: Drive shaft U-Joint clamps/brackets
« Reply #1 on: December 30, 2015, 03:42:19 PM »
Got a photo?
« Reply #2 on: December 30, 2015, 04:05:47 PM »
I suspect you mean '.. two brackets holding the rear most U joint to the differential..'?  :)
U-joints are pressed into the driveshaft...
« Reply #3 on: December 30, 2015, 04:50:48 PM »
I agree with John, a photo may help.
