Author Topic: Heater box gaskets in kit  (Read 4377 times)
« on: December 10, 2015, 01:49:37 AM »
Hello list,
  I searched the archive but could not find an answer to if the original '67 heater box had a gasket between itself and the defroster input at the bottom and also the defroster output to the dash openings. I have these in the heater pad kit. I don't see any in the '67 04B LOS car.
Thank You,
Re: Heater box gaskets in kit
« Reply #1 on: December 11, 2015, 08:44:44 PM »
Hello list,
Thank You,
There was no gasket or seal between the defroster outlet on the top of the heater box and the inlet at the bottom of the Y-shaped defroster duct; Chevrolet design practice on all cars and trucks was to leave that gap open without a seal so the noise and vibration of the heater box didn't get transmitted through the duct to the upper dash panel, which would then amplify the noise.
« Reply #2 on: December 12, 2015, 12:42:27 AM »
  That's good news as I didn't put them on when I reinstalled the heater assembly and your reason makes sense. I didn't record any when I removed the box nor did the LOS assembly showed any signs of it. It's actually a close enough fit, yet have a gap, to not need any gaskets there.
Thank you, John.
