Thanks Miller,
Originally frost green, someone put a quick thin coat of primer over the outside, some of the original black stripes show through in spots, however door and trunk jambs still have original paint. Has white deluxe houndstooth. Someone added spoilers and cowl hood way back when, probably when they threw a quick coat of primer on the whole thing just to make it all one color again, but I believe the car to be a flat hood and no spoiler car. Been sitting like this for 30 years, before that not much history and car hasn't moved. Trim tag reads X33, interior is 729, paint 59, and is a 12D build.
I'm still up in the air on the rearend because I don't know what the date spread would be on the axle housing during that time period at Norwood. The rear predates the data plate on the car but I'll have to get back under it and do some cleaning to get a good read on all of it. it's caked with 46 years of grime. Planned to move this thing over to the lift soon, clean, power wash, start on the brakes etc...I should be able to read the casting numbers better that way. From what I can see so far it's the early casting housing and I can make out the model year of 8 (1968), I need to clean more to see the month clearly. I can also make out C....BL so it's stamped with the C spaced away from the BL for some reason.
Anyway, you are more than welcome Miller, just give me a shout on here before hand, I'll give you contact info and set something up. I'll be at BJ this year as well.
